Question about RCA 39" class LCD HDTV 39LB45RQ - ON Corp US, Inc
Broken screen color is off kind of like a spider web
2 Suggested Answers
  • 42 Answers
SOURCE: I AM HAVING COLOR PROBLEMS
Sounds like you might have yellow sac spiders. They like going on the inside of electronic components (i.e. cars, radios, tvs, computer towers, etc). color issues are normally associated with Color Wheels or chip-boards. Spiders can easily screw this up. Get a Compressed Air Can (like cleaning your keyboard) and clean it out. make sure you unplug the unit before you do this. You will be able to see better.
To get inside you have to take off the back panel. There should be about 14-20 screws holding it on. Be very careful. taking it off. if you need to get another person to help pull it off. You may have to open up other panels to get to the screen. Check out your lamps and wheel to see if they appear damaged or blown or charred in any way.
Posted on Mar 10, 2011
I dropped my dell notebook on the floor. The screen is 80% frozen however when I turn it off and reboot I can tell from the little corner I can see that the computer function but the screen stays stuck....
Try connecting an external monitor to your laptop via the 15 pin VGA connector located on the left side of the laptop.If the laptop display is normal on the external monitor then most likely your LCD (liquid crystal display) panel is damaged and needs to be replaced. The spider web effect is due to cracked display panel.
Sep 12, 2011 | Dell Inspiron 1525 Notebook
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I AM HAVING COLOR PROBLEMS AND HAVE SPIDER WEBS ON THE INSIDE OF THE SCREEN. WHAT IS CAUSING THE COLOR PROBLEM AND HOW DO I CLEAN THE INSIDE OF THE TV?
Mar 10, 2011 | RCA HD52W59 HDTV Projection Television
Spider webs behind screen
Pardon me but do you mean the screen has spider web looking patterns all over it? Or are you saying that spiders have crawled into your set and spun webs to catch flies?
If you have a spider web pattern problem then something has impacted your television screen and it is broken. You can check and see if your homeowner's insurance covers this, contact a service provider to see if they want to buy the television for its parts, and contact Mitsubishi to see if they offer a discount or pro rated rate on a new or refurbished television for when things like this happen.
If the problem is that you have spiders in your television I do not recommend vacuuming it out. I have seen people's televisions go out after they attempt to remove dust and webs that way. In this instance I also recommend contacting a servicer and the manufacturer.
Jan 28, 2011 | Toshiba 57HX83 57" Rear Projection...
How to fix Polaroid TDA - 03211c screen has spider web crack and colors?
Normally it is 80% of the cost of a new television to fix one with a broken LCD screen. You can check with whoever is going to repair it to see how much they'll charge and how much they can get another LCD screen for. You can see if a service provider will buy the television from you for parts. You can see if your homeowners insurance covers this.
Aug 20, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Tv screen is broken
Broken screen,need to be replaced if available to repair it will cost more than a new 32" lcd.
Mar 22, 2010 | Sanyo DP32746 32 in. LCD Television
Spider web screen..
yes lcd is broken. repair is usually around 120.
Jul 10, 2009 | Fuji FinePix Z10fd Digital Camera
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Broken Screen
screens cost about 1000 and up - usually not worth replacing
Feb 25, 2009 | Philips 52 In. LCD HDTV
Appears that lint is on one of the lenses
this could be a contaminant inside one of the lenses, or possibly spider webs inside the tv.. This is a very common problem. Remove the back of the tv, you will be able to look around the back of the screen with a flashlight and see if there are any spiderwebs. at this time you should also clean your lenses and mirror with some glass cleaner . this will improve your picture as well.
Nov 05, 2007 | Toshiba 46H83 46" Rear Projection...
Open Questions:
See all RCA 39" class LCD HDTV 39LB45RQ - ON Corp US, Inc Questions
RCA 39" class LCD HDTV 39LB45RQ - ON Corp US, Inc Logo
10 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
