Question about Honda HRX217VKA Lawnmower
Won't start after winter lay off
Won't start after sitting for three months
    Master:
  • 969 Answers
Flush gas tank. Fill with fresh gas with Stabil. Remove bowl from carb clean. Replace air filter. Replace spark plug. Enjoy!
Posted on Jul 04, 2015
I have a 1994 chevy surburban with a 6.5 turbo diesel and it hasnt been plug in for a few month so i was wondering what would b the easiest way to start it and what can i do to make it easier to start for...
By plugging it in I assume you mean the block heater for the engine.
I would plug it in for an hour or two before starting. also give the glow plugs plenty of time to heat up before starting. If you don,t have a garage to put it in try to find a place out of the wind and with direct sun in the day this may help some. laying an old blanket or quilt or even a tarp over the hood and front end could help some. after sitting for a prolonged period of time in cold weather hook a charger up to the battery before starting to top off the battery's charge. Hope this helps.
Dec 30, 2013 | Chevrolet Cars & Trucks
It has been sitting or 3 months and won't start and it is a kick start Suzuki 4 wheeler and it was running great 3 months ago but this cold whether I think is what the problem is .
Hi erik
My first point of call would be to clean the spark plug, it could have gotten corroded while the bike has been standing. Hope this helps.
Feb 20, 2013 | Motorsports
Hello there! I have a 1979 Harley-Davidson FXEF 1200 that isn't starting. I have replaced the battery and the spark plugs and it still won't start. Once in awhile the pistons get combustion but...
If the bike has been sitting for six months, the fuel that was in the float bowl probably evaporated. When it does this, it leaves behind a gummy substance that is actually the additives that the refineries add to the fuel for various purposes. The problem is that it has probably plugged up the jets in the carb. You need to take the carb off the engine, disassemble it completely, and soak it in professional grade carb cleaner. If you don't have the mechanical knowledge to do this, I'd suggest that you take it to someone that does. If the carb is a stock carb, it's a Keihin butterfly type carb and they can be very finnicky about the float needle setting.
Good Luck
Steve
Jul 25, 2011 | 2011 Harley Davidson FXDF Fat Bob
I have a 1999 gmc sierra with (as of 30 days ago cat. converter, fuel pump and filter, cap and rotor) changed in garage. regular oil changes, tune ups as of 8 mths. it has lots of cranking power, but...
If i understand you right the truck has been sitting for two years.If it has been sitting that long without running or moving the gas has turned to varnish...I suggest that you drain and refill the fuel tank,and replace the fuel filter located on/in the frame rail on drivers side.
Jun 18, 2011 | 1999 GMC Sierra
After I drive my truck (1990 pickup, V-6, 4-wheel drive) for a while (20 minutes or more) and then shut it off, when I come back it won't restart and I have to jump off the truck or if I let the truck...
next time this happens get someone to hold the key to start if manual with clutch in and tap on the sterter with a hammer or something. if it starts you can just replace the starter contacts or the starter
Jun 15, 2011 | 1990 Toyota Pickup
J.D.x300 tractor 8 months old will not start. It started 3 weeks ago after winter storage. Fuses good,tank full(has fuel stabilizer),battery charged, brake is on,throttle is advanced, choke is on,sitting...
ok a couple of things to try 1 try using starter fluid in carburetor 2 second spritz and crank does it fire or pop? if yes then there is spark, if not then pull spark plug and put new one and try again, if no then leave spark plug out of engine and lay on engine with wire connected and look for spark( do in shade to see better. if no spark then coil if bad. if it does fire on starter fluid, check gas filter and air cleaner it may be too lean or rich to fire properly.
Apr 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Trans won´t engage when cold
cleaning the valves for trans conversion might but that is up to a pro do not atempt yourself
Apr 03, 2010 | 2001 Jaguar XJ8
Yamaha XVS650A will not start
have you emptied what after three months will now be stale fuel and filled with fresh also fuel has a nataural wax which adheres to internal carby parts ie jets needle &seat it may bethat the needle is stuck in the seat which wouldefectively block fuel flow int the carb this can often be remedied by simply tapping the float bowl a couple of times with lite a soft faced hamer or the handle of a screwdriver if the only hamer you have weighs 12lbs & comes with a three ft handle. failing that it will be nessecary to strip & clean the carby.It would also be advisable to check & clean the electrical conections at the fuel pump spray electrical contact cleaner is Ideal for this
Feb 21, 2010 | 2003 Yamaha V Star Classic
Location of the fuse box on a 2006 victory vegas jackpot
i had the same problem last winter. my problem was the bat. had power but not enough to open the injectors. might want to take a look at that. jump the bike and try to start it.
Mar 13, 2009 | 2006 Victory Vegas Jackpot
Honda HRX217VKA Lawnmower Logo
88 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
