Question about Konica Minolta Bizhub C300 All-In-One Printer
P7 p28 p5 c300
Pb konica miolta
  • Konica Minolta Master
  • 6,696 Answers
For P-7 replace the magenta image unit
for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 10, 2016
Miolta c300 c3851
Fuser Error. Could be fuser or bad power.
Hold down [Utility/Counter] while turning the main switch on. Press [Reset] on the touch screen, and turn main sw. off/on.
May need firmware and/or software switch setting in service mode.
Change software setting. Service Mode System 2 Software Switch Setting
switch no: 50
bit assignment: 00000001
hex assignment: 01
May 21, 2014 | Konica Minolta bizhub C250 All-In-One...
Miolta cs pro 2030 C05
sir/mam Reset button is located behind the copier remove the rear upper cover you see a circuit board with machine on depress the small black button on the board. If the code comes back then the fusing unit the hot part is broke could be thermistor, heat fuse, heat lamp or the board that controls it. Have a tech look at it. DO not continue to reset or a fire can occur that would ruin a perfectly good day :) Code is for the FUSER!!!! (HOT PART)
Mar 13, 2012 | Minolta Office Equipment & Supplies
Miolta 620 copier code c 0540
access panel inside the front door
Nov 24, 2011 | Minolta DiALTA Di620 All-In-One Laser...
Miolta PagePro8e: I search for driver for Windows7 (64bit). Can you help me?
NO that machine is a legacy machine form Minolta which had it under QMS now Minolta is Konicaminolta try their web site but doubt you find a driver for that a machine on window 7 best bet would be windows 95 at best xp
Jul 05, 2011 | Minolta PagePro 8E Laser Printer
C 0204
C0204 is an error to tell u that behind the tray 2, you'll have a paper that satyed after a jam. remove the paper, and push the interrupter ON/OFF. it will solve the pb.
Jan 17, 2011 | Konica Minolta bizhub C250 All-In-One...
Map loading impurient client files kikked out
Oh god, poor you dude. That's an arbitrary PB kick. That means PB believes your client file is hacked or some other nonsense. This is a PB problem, there is no fix, just try to reinstall your game and delete all your player profiles. This is one more reason to hate PB...
Mar 10, 2010 | Video Game Consoles & Games
Requests new cyan toner...error light flashes 1 sec intervals
the toner carridge is stightly out of rotation, if you manually turn the carridge 2 notches this will reset itself when you close the cover.
si
Jun 24, 2009 | Konica Minolta magicolor 2400 Laser...
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Fax is on pulse dial
Go to the Utility menu, select "Administrator Settings" (password required) from there , fax settings, telephone line. In here you should be able to set the dialing method. There should only be 2 options, just pick the other one. (PB is for tone i believe)
Oct 31, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub C300 All-In-One Printer Logo
121 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
