Question about Quiksilver Lanai Watch
Watch band broken
Where to get new band
Broken band, how can I get new rubber band? where??
It looks like that may be a custom band, this site has some great bands, http://www.watch-band-center.com/shop-watchstrap.html?gclid=CjgKEAjwoJ-dBRDbjfKN7IzN0FsSJAAP0G_DR8AwTfhcxt7HHIHONLoaf1QZfq7YeqCB6Vt1_oZKV_D_BwE
you'll need to measure how wide your band is where it connects to the watch to ensure you get the correct fit.
Jun 24, 2014 | Ducati Cw0025 Desmo Watch for Men
How much does it cost yo get new band
Jewelry store,dept. store ,or the manufacturer.
May 30, 2013 | Timex Expedition 84601 Wristwatch
Had rubber band fitted, instead of metal band, when new. Rubber watch band is perished and broken. I need a new metal band, Please. The model watch is :- Sector 700 2653700015
ebay is your friend, look there and you should find one.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Sector 700 2653700025 Watch
My santos de cartier band got broken; I spoke to Cartier and they told me if I return the broken band they will supply me with a new one within 2 months but I am horified by the price. It will cost me $au...
Cartier is not the only company playing this game. Rolex invented the trade in game and now other high end Swiss brands are jumping on board.
Because you need or want the genuine band you have to put up with their game.
Sorry this isn't better news.
Ken
Yellowstone Watch, Inc.
www.yellowstonewatch.com
May 21, 2010 | Cartier Santos W20056D6 Wrist Watch
How do i change watchband for casio bg169wh
Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Broken wrist band
    The easiest is to bring it to Wal-Mart, or another store with a watch section in their store, if you buy a new wrist band, they;ll put it on for free. If you're feeling DIY, pull the watch band to the side, untill the metal bar inside is ejected form the slot in the watch, from there, insert the new band's bar into the slot, and voila!
    Nov 15, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
    I have broken my wrist band for my watch.....
    You should be able to purchase a replacement band at any local watch dealer. They will need to measure the width of the band where it connects to the watch, and then can offer you a variety of styles to choose from for a nominal cost.
    Mar 25, 2007 | Vanceur Royal Castle CG35S Wrist Watch
    Quiksilver Lanai Watch Logo
    Top Quiksilver Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Quiksilver Watch Expert? Answer questions, earn points and help others
