Question about Garmin GPSMAP 430 GPS Receiver
Gpsmap 180 firmware corrupt
Aquired a used gpsmap180 that worked great...but wanted to upgrade firmware using ac/pc interface cable and lates firmware ( GPSMAP 180 Ver. 4.04/4.05 as of March 29, 2001). my notebook, on batteries went to sleep.
firmware on gps got fried.  now cant bootup, cant operate gps, cant reload...dead.   when I turn on GPS it says on screen "UPLOAD NOT PRESENT"  Garmin says unit not supported and can not send it in for repair.
This unit came with boat I bought.
  • 317 Answers
Re: gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Posted on Nov 01, 2007
0 characters
3 Points
Garmin 76cs will not aquire satellites after powering up
plug it into a computer and update the firmware. my TomTom has done that a couple of times.
Aug 29, 2012 | Garmin GPSMAP 76CS GPS Receiver
I tranfert bluechart from my PC using mapsource to
I recommend upgrading your system software to the latest version (5.30),
follow this link for directions and the file's location.
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
  5. Load the SD card into your GPSMAP 545s and turn it on to replace the system software of your unit.
I hope that helps.
Jul 04, 2009 | Garmin GPSMAP 545s GPS Receiver
I have 2 data cards for Garmin gpsmap 180 and working well.I got this offshore boat from Tallahasse 3 wks ago that has a built in Garmin gps 180 with 2 data cards on it and I have no use for it because I have the boat in Texas now. Don't know if this is the right one that you need, all I know is that these 2 cards are programed for Florida gulf.I can ask the previous owner of the boat about the details of these 2 cards. I'm willing to trade it for a data card for the lower gulf preferably from Brownsville, Tx. to Louisiana or anything that will cover Port Isabel, Port Mansfield, Port Aransas. You can e-mail me at or call me at (956) 240-8420 .My name is Oliver.
May 09, 2009 | Garmin GPSMAP 180 GPS Receiver
Unit shuts off after a minute or so
i have the same problem. i just read that it maybe a software rather than a hardware problem. updating the firmware will "Fix bug on Data Card Information page to prevent unit shutdown"
...trying to locate a pc interface cable to install...
Mar 28, 2009 | Garmin GPSMAP 172C GPS Receiver
I turn my GPS on and it kept showing GPS 1% firmware. Can you please tell me how to get rid of this problem
Please go to the Garmin website at and download their webupdater on to your PC. Connect your Nuvi to the PC with a USB cable and run the webupdater. It will check to see if you need ay firmware upgrades and also look for a selection called GPS chipset. You want to upgrade your Nuvi with the GPS chipset. Your GPS receiver has corrupted data and needs to be reflashed.
- Jim
Nov 21, 2008 | Garmin GPS Devices
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
Garmin 180
You need to replace the internal Battery with the Panasonic BR2032-1F2 battery. However, yes your waypoints will most likely get lost when you do this.
May 07, 2008 | Garmin GPSMAP 180 GPS Receiver
Garmin GPSMap 60 CSx USB Connection
Actually, I just solved the problem myself...
I went to Garmin's driver download site ( and got the latest USB driver (2.2.1) for the 60C. (Although, it appears that that driver pertains to all Garmin products, not just the GPSmap series or the 60C.) Installation instructions are pretty much standard for Windows drivers, so it's easy.
That: a) Garmin requires special USB drivers for their product is finicky (most USB-connectable products just connect automatically using Windows' generic USB driver), and b) my unit -- which had always worked just fine, and suddenly stopped connecting out of the blue -- remains a mystery. Nonetheless, a driver upgrade was the final step that I needed. (Although, I also swapped USB cables and upgraded MapSource, too, so maybe it's some combination of those things.)
Dec 15, 2007 | Garmin GPSMAP 60CS GPS Receiver
Locating satellite
Initialization time has been greatly reduced with newer system software upgrade for the Garmin GPSMAP 545s. Get your system software upgrade here.
I hope that helps.
Aug 30, 2007 | Garmin GPSMAP 545s GPS Receiver
Garmin GPSMAP 430 GPS Receiver Logo
217 people viewed this question
Top Garmin GPS Devices Experts
Tom Chichester
Jonathon summesfield
Bill Gilhooly
Bill Gilhooly
Are you a Garmin GPS Device Expert? Answer questions, earn points and help others
