Question about Samsung - Projection TV replacement lamp Projector Lamp
I bought a tv lamp from amazon march 6
I put the bulb in and it wreced my tv i had a tv repair company look at my tv and it did 469.00 worth 0f damage to my tv
I have bought the biggest lemon in this tv than ive ever seen before..shortly after buying it, i had green swirly lines throughout the whole picture...had 2 repair guys out here,1 replaced the "mother...
Lamps have a limited life. They useually last 1000 hours or so. If the TV is on from 07:00 until say 23:00 every day, that equates to 60 days.
There is no such lamp as a "One time replacement lamp" as they do not last for ever.
The average life of a lamp is just about 6 months.
If the picture is cloudy is probably needs the optice cleaning. It is very fiddly and damage can occur easily so get an authorised Hitachi repair service department to clean it for you. It should be carried out in your home and will take less than an hour. If anything gets broken, it is not your problem if they are heavy handed.
Hope that helps.
Feb 03, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
YELLOW SCREEN
How old is the lamp? the lamp may be failing and or the optical block may be damaged.
Jul 13, 2008 | Mitsubishi VS-45609 TV
I have a sony Wega KDF 46e2000 and a couple of months a go it started going off and on by itself. And the local repair shop said we needed a new bulb it was going bad. So we bought one a month ago and I...
Three blinks is a lamp cover error. Make sure the lamp cover is back on securely and try again, there is a switch that does not allow the TV to turn on unless the lamp cover is on correctly.
If this does not work, then it means the lamp cover switch was damaged when you were putting the new bulb in and you need to get the switch repaired or get a new switch. They are two of them and cost about $15 each.
Oct 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Panasonic PT50LC14 Power issue
We have a PT-50LC14. We replaced the lamp 6 months ago with a TY-LA1000 bulb we bought from a company online (not directly from Panasonic) and it worked for 6 months. Then the TV started turning off on it's own...sometimes it would not come back on for an hour or so. We called the lamp company and we luckily had 1 day left on our 6 month warranty!! They sent us a replacement bulb and the TV would never power on. It would try to power up, but the bulb would never ignite. The power light would flash and then the lamp light would flash every 5 seconds. I had a friend that has the same type of TV and she ordered her bulb directly from Panasonic. I borrowed her lamp and it powered right up. We then called the online company and they sent us yet another replacement bulb, and I tried it today and it works. It seems like these TVs are very particular about the type of bulb used. Next time, we will be ordering ours directly from Panasonic and just paying the extra $100. We have been without our big screen for 2 very long months! I had called a local tv repair shop, called Panasonic directly, and read through countless internet forums, and I thought we were going to have to replace the ballast or get a ballast repair kit and start messing with the circuit board.
May 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Sony KDS-R50xBR1 Needs projection lamp replaced
I bought a True replacement from the PartsStore through Amazon.com and it cost me about $185, but it was a Phillips bulb and the full cartridge replacement. I went with the aftermarket bulb only replacement the first time, lasted less than a week and haven't resolved that issue yet.
Apr 06, 2009 | Sony KDS-R50XBR1 50" HDTV
Panasonic TY-LA1000 has good lamp, but black screen. light is blinking green, then solid green, then after some time goes red?
Jan 11, 2009 | Panasonic TY-LA1000 Projector Lamp for...
TV won't turn on - just replaced lamp
I had this same problem. This (panasonic) set is sensitive to the type of bulb used. Don't use a remanufactured one, get a philips/osram or an OEM. If that is what you have, move on to the ballast. Replacing the ballast isn't easy, if you are electronically inclined, you can remove the back panel and the page size aluminum brace, it has two large square cut outs. The shiny silver box under that brace ( maybe 10" x 4") is the ballast. That is typically the next thing that goes out. The bad news is the cheapest I have ever been able to find a replacement was around $350. But again, if you have soldering skills, order a ballast repair kit from ebay ($30) and go to work. If you decide to do that, let me know and I'll email you photos and walk you through it. Once the ballast has been repaired, if it still has the problem, The power supply is bad. At that point take the bulb back out and sell it on ebay or send it back and use a LFH (large F****** hammer) and take out your aggression. Its not worth fixing. The powersupply board is more than the TV is worth. Most of the time this problem is fixed with the ballast. But its a CHORE to get to it and remove it to work on it. I'd be happy to help and I can send vids and pictures, depending on what you'd like to do.
Good Luck.
Jan 11, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Hitachi #55VS69A
I had this same problem over the summer, I had my TV for two years before it went out. You need a new lamp. The lamp is not hard to replace on your own. However, you MUST make sure that you do not touch the lamp (the bulb part) in anyway. If you do your new lamp will not last as long. You can order the lamps online. They range anywhere from 150-300 dollars online. However, I found a TV repair company in my city that only charged me 100.00 for the lamp and they told me If I took out the box that holds the lamp they would replace the lamp for me. They also gave me a 1 yr warrantee on the lamp. All I had to do was un-screw the box from the back of the TV take the box to the TV repair company and I placed the box back into my TV. My TV works. While going through this process, I learned that these lamps go out all the time, the more you watch the TV the more often you'll replace the lamp. I was told from the repair company it could be as often as every year. The Lamp does have MURCURY in it so if you replace the lamp on your own be careful and have it recycled. If you live in SLC UT the repair company I went though was Village TV Sales and Service.
Jul 15, 2008 | Hitachi 55VS69 55" Projection HDTV
Need a replacement lamp for LCT50HV-tv syntax
Not looking good for your problem. I have not been able to find a supplier on the web or ebay. You might have to call the company and order it from them, but I bet it won't be cheap.
here is there contact page:
http://www.syntaxbrillian.com/company/locations.html
Product Support
Olevia Product Support
Call Toll Free: 1.866.9OLEVIA
or 1.866.965.3842
If this TV is less than 1 year old, you should still have the manufacturer warranty.
You should read the customer review at amazon:
http://tinyurl.com/34owj9
Feb 14, 2008 | Sony XL-2000U Projector Lamp for XBR800...
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
