Question about Motorola Mobility Whisper Bluetooth Headset
Voice command Brand new whisper. One day the voice command worked, the next day it didn't. Do I need to reset something, if so how?
2014 F150 Lariat Sync Voice Command problem?
It sounds like it should go to the dealer for warrenty repair.
Aug 24, 2014 | GPS
Motorola reset
Hi
Are you talking about voice command on your device or voice command on your phone? Are you doing a long press or a short press of call button? it will behave differently based on how long you press.
Mark
Motorola Support
Aug 19, 2014 | Motorola Mobility Tx500 Bluetooth Car Kit...
Roma Shoprider Whisper S-787NA keeps stopping, batteries are brand new
It appears you are equipped at least a bit for troubleshooting and have your back to the wall with such a distance to go for help. If you have a troubleshooting manual or can call the closest place for troubleshooting help that would be a help. I would expect that there is something happening that is causing an overheat or overload switch to trip. Turning it off would reset things and you go again. I wish you well with figuring this out.
Mar 12, 2012 | Health & Beauty
My linksys router doesnt have a default gateway and the reset buttton on the router doesnt work either
When you look between the Ethernet port and Power button, there should be a reset button there you should hold for 5 seconds. Of course if you do that, If you changed Network name and key that will be reset to the default settings, Also is wireless network showing when you pull up the Networks? You can leave user name blank, but default password is admin. Also email me with more info I will be glad to help
http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&app=vw&vw=1&login=1&json=1&docid=1e97db4854604b0fb5cc8c0d74491e35_19584.xml
Dec 26, 2011 | Linksys WRT54G3G Wireless Router...
Smashed my screen on my mda vario got a new phone now want to active sync in but cant remember my pssword is there a work around?
Yes, you need to perform a hard reset.
To perform a hard reset
1. Press and hold the Comm Manager button and Voice Command
button on the device. At the same time, use the stylus to lightly
press the RESET button.
T-Mobile MDA Vario hard reset soft reset hardreset softreset
2. Keep the Comm Manager button and Voice Command button
pressed, and the following message will appear on the screen:
3. Release the two buttons, and press the Send button to perform a
hard reset
Feb 05, 2011 | T-Mobile MDA Vario Smartphone
How do I get my lg ally to respond to a voice dialer call command from my Jawbone bluetooth?
Hi bredebar you need to go to settings. Next you need to hit the wirless &network go to the bluetooth settings and make sure that the blue tooth is connect to the phone and audio. If your having a problem with the voice command it is because your ally doesn't have froyo on the ally. You need that to get the voice commands to work. you can go to the open market and put in voice commands for droids. Hope this helps foryo is frozen yogurt great name. There is another new program coming out be on the lookout for it .
Jan 03, 2011 | LG Ally Cell Phone
I have a garmin 3970t and the voice command does not work
The Garmin's not very good at recognising the default set phrase to initial voice command; i.e. "Voice Command". If you bring up the Tools menu, and touch Voice Command, it will tell you what phrase it's expecting to hear and provide a button to touch to customise it. The default, as I said, is "voice command", but for some reason, it thinks it's pronounced something like "Vwuss commont". Try it. It might work!
I changed my voice command phrase to "Voys Commarnd" (I'm English - it's how my accent would be written phonetically). It now works most of the time without a problem.
Aug 12, 2010 | Garmin GPS
My Cannon Printer
in ur computer 2 printer are installed 1 is ur new printer & other is old one so select ur new printer asa defolt printer
just go control pannal>printer rihgt clcik on new printer & set as defolt
or
delelt the old printer
Mar 06, 2008 | Canon PIXMA iP1600 Printer
Motorola Mobility Whisper Bluetooth Headset Logo
35 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
