Question about Bosch HBL 5056 Electric Double Oven
Oven roof hanging down
Roof hanging down in top oven/grill
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
Heating element hangs down in Miele oven
Hi dose it look like something broke off on the top of the oven , usually they have a small bracket with a screw in it , do you even see a hole for a screw ?
Dec 12, 2011 | Miele H4780BP Stainless Steel Electric...
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
My grill element on my zanussi oven, ZBF 260, has stopped working. How do I remove the faulty part so I can replace it?
after isolating electric. remove oven from housing ( 2 or 4 screws) remove back of appliance to access retaining nuts .( disconnect wires noting terminal position). grill is fixed to roof of oven with screws remove these and take out grill. refit in reverse order remember to reconnect wires .
Aug 24, 2010 | Zanussi Ovens
My grill element looks as if it has melted and
From the description you have given it would seem as if the element is'gone' i.e broken.
You will need to have it replaced before it does any more damage to the oven roof.
Jan 06, 2010 | Zanussi ZBF360X Electric Single Oven
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
I have a stoves 720EF Heritage - electric - the top grill is not working - does it have a reset button?
No, there is no reset button. However, the grill will only work when the front is down as there is a microswitch which operates to provide connectivity when it is in this position. This is to stop the grill overheating. The switch could have gone faulty.
Does the top oven work ok?
When you operate the grill there are two options, part or full. Are they both failing? Does the cooling fan switch on when either grill is operated?
May 05, 2009 | Stoves 720EF Electric Double Oven
Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Neff U1421 Double circotherm Electric Oven
The screws holding the grill element to the roof of my Electrolux oven have come out.They can be removed in order to clean the roof of the oven. According to the manual, it is easy to screw these back in...
Possibly held with self tapping scerws, and hole has enlarged, all you will see are 2 small holes if this is the case, then use larger screws..
If this helps, please leave positive feedback. Thanks
Nov 26, 2008 | Ovens
Bosch HBL 5056 Electric Double Oven Logo
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
