Question about Harman Kardon DPR 1001 7.1 Channels Receiver
Dpr 1001 Connect to hd tv
Have a Panasonic TH-37PX60U tv - can I hook it up to a HD Satellite receiver - have a Bell hd but don't get any reception
Your plasma tv will display HD content when you connect an HD source (Blu Ray Disk, Sony PS3 / PS4 or Xbox 360, HD Cable Box, HD satellite, etc) via the TV's HDMI1, HDMI2, Component1, Component2 jacks or if you connect a UHF/VHF TV antenna (not cable box, etc.) to the "Ant" connector *and* you're close enough to a broadcaster with HD content to view.
Using any other input will produce only the lesser quality SD video signals. Review the manual - linked below - to help you connect the components you have.
http://service.us.panasonic.com/OPERMANPDF/TH37PX60U.PDF
May 13, 2015 | Panasonic TH-37PX60U 37 in. Plasma HDTV
How to use D-Link DPR-2000 with OSX
Its a 4 port printer server. You can connect up to 4 printers to the system and then everyone who has wireless connection with the server can use any of the connected printers.
The system should be easy to install and can be used with windows and OSX.
I wonder why someone should buy a printer server if he / she does not know how it works.
In OSX you you have to use the IPP and Dlink offers their special Click and Connect software.
Read the manual and it will work.
Jun 26, 2014 | D-Link DPR-2000 wireless print server,...
HK DPR 2005 is shutting off by itself after running for about 5 seconds
when you connect any device you should always have the power off. if you connect while power is on you will blow that input up after time. sorry for the bad news
Apr 13, 2014 | Harman Kardon DPR 2005 Receiver
DPR-1040 does not connet wirelessly
Wireless router must not use WPA2. Change to WEP or WPA or buy a more modern printer server,
Jan 05, 2014 | D-Link DPR-1040 wireless print server,...
I have a Harmon Kardon DPR 1001 and I added an additional set of rear speakers and on the OSD it is not recognizing the speakers
Register and download the owner's manual and reference guide (service manual) for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-DPR-1001-Receivers-manual/id/386ci259/t/2/
On page 19-20 you must tell it that it has surround back speakers (something other than NONE). They aren't just 'recognized'.
Apr 23, 2011 | Harman Kardon DPR 1001 7.1 Channels...
Can you connect to a hd tv
you can connect any tv if you have the correct connectors. if you have an hd tv make sure your video card is high definition and can support the correct resolution
Jan 18, 2010 | Dell Dimension 3100 PC Desktop
When trying to set up Samsung CLP 310 I cannot get the software loaded. Sony notebook VGN SR220J. Server works fine from 2 network connected PC's I've tried it from the disc and the loaction on the HD.
download latest drivers and install with printer unplugged...it will install software to c:\program files\samsung\ and then 2 more folders in you will get the drivers folder - add printer and just do have disk and browse to that folder.
Aug 01, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
D-LINK DPR 1260 NOT DETECTED
did you install the software that comes with the print server? if so, did you configure the software to recognize the printer?
Apr 30, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
Sep 28, 2008 | D-Link DPR1260 Rangebooster G...
Printer eventually loses connection...
Try to upgrade the firmware revision to the last one (1.21).
I had similar problem with the dpr-1260 firmware rev 1.00.
Now after the firmware upgrade the problem seems solved
Nov 06, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Harman Kardon DPR 1001 7.1 Channels Receiver Logo
12 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
