Question about Saws
Reciprocating how does a laser oil control work on a bitzer semi hermitic compressor
3 Suggested Answers
farfield
  • 462 Answers
SOURCE: compressor winding problem
A 3 PHASE COMPRESSOR THAT LOOSES A LEG WILL NOT RUN. SO BE SURE YOU HaVE all 3 legs and check the legs across to each other with your vom, and then to ground. any leg not showing up for the compressor wires may indicate you need a NEW CONTACTOR. Check this and see if you get the same readings.
Posted on Jun 19, 2009
  • 49967 Answers
SOURCE: How to top up refrigeration oil without original plug for bitzer compressor ???.....
refrigeration oil moves around the system with the gas and is not topped up or changed
new compressors have sufficient oil already in them and any items removed will have insufficient quantities to affect the quantity of oil required
Posted on Jun 02, 2016
Jun 02, 2016 | Refrigerators
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    WILL T21 SELECT OIL WORK IN A MODEL 2475
    The solution was easier than I expected. Ingersoll Rand "Select" oil is a synthetic oil recommended by Ingersoll as better than mineral oil. T30 (mdl 2475) and T21 are different styles of compressors. So, yes "select" oil can be used in the Model 2475 compressor.
    Jun 25, 2014 | Ingersoll Rand - Rand Type - 30...
    We have Ingersoll Rand Type 30 Reciprocating Air at about 20years old.. what type of oil is used in the crankcase?
    Almost all compressors use sae 30, you can buy it labeled compressor oil. The key is compressors use a non detergent oil.
    Mar 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
    Ingersoll rand compressor type 30 is not unloading. Auxillary valve seems to be dirty with oil and at 150 psi the compressor is not unloading.
    It sounds like the pressure switch is bad or out of adjustment. Typically the pressure switch is set at 175psi on a 2340. If the auxillary valve you are speaking of is on the pressure switch and is constantly blowing air from it you have a bad receiver tank check valve. Also if you are getting a lot of oil out the valve at the pressure switch you may have some oil control rings bad.
    Feb 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
    Model 2545 compressor getting toomuch carbon deposit in side the cylinder
    You can try switching to a full synthetic compressor oil to alleviate the problem.
    Carbon is caused by the over heating of oil. Your problem is most likely an undersized compressor, or worn valves and piston rings.
    Regardless of the problem synthetic compressor oil will help.
    Hope that helps,
    under_psi
    May 16, 2010 | Ingersoll Rand - Rand Type - 30...
    Compressor winding problem
    Jun 19, 2009 | Jenn-Air Freezers
    Oil port location and oil type for an old Sears portable utility
    Just use capella oil. This is the type of oil used in hermitic motor-compressor units. So, this is readily
    available in refrigeration hardwares in your area.
    Mar 28, 2009 | Plumbing
    Saws Logo
    Top Saws Experts
    Tom Chichester
    ray gallant
    Are you a Saw Expert? Answer questions, earn points and help others
