Question about Olympus FE-20 Digital Camera
Pc not reading fe 20 olympes
Camera not recognized by pc
How to remove the write protect on my olymps digita cmera mode no FE-5020
Remove memory card from the camera, look along the one side for small switch, the switch that is furthest from the contacts is in the unlock position allowing access. If you find it is in the unlock position slide it back forth to clean switch contacts, if this fails replace the memory card.
Mar 20, 2012 | Olympus FE-5020 Digital Camera
Usb camera olympus fe-210 not working ,ill try manny times but nothing happens
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Jun 03, 2009 | Olympus FE-210 Digital Camera
My fe 310 didnt recognize by my computer
Apr 24, 2009 | Olympus FE-170 Digital Camera
I can't transfer the images from my olympus master 2 Fe-270 to my pc, it says the device is not ready. what's the problem?
Apr 11, 2009 | Olympus FE-270 Digital Camera
I have a olympus fe-170 a got from a friend i would like to print
Mar 27, 2009 | Olympus FE-170 Digital Camera
Computer won't recognize Olympus FE-340 when USB is plugged in
some computers just seem to do that, it happened on me before. if you have a card reader just put the card into that and read the pictures from that.or just try a differant port if you havent allready
Mar 24, 2009 | Olympus FE-340 Digital Camera
FE-160 won't switch off
Try removing the battery, let it stand for 1 hour (it should reset itself), insert the battery and configure your camera again.
AND/OR
Have a look at your manual and or the Olympic WEB site to see how to reset your camera.
Nov 12, 2008 | Olympus Camedia C-160 Digital Camera
My Olympus FE-340 is not recognized by my PC operating on XP
Aug 06, 2008 | Olympus Cameras
Need a driver for FE-190
need a driver or cd to download my pic on my computer olympus FE 190
Mar 30, 2008 | Olympus FE-190 Digital Camera
Olympus FE-20 Digital Camera Logo
19 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
