Timeguard fst17a problem
Timer is on but it is not heating the towel rail
I need two brackets for my 60watt creda heated towel rack
I think that is very unlikely as they seem part of the tube in manufacture. You could contact them direct. The only other alternative would be to use plumbing pipe clips, but they are a bit industrial.
Here a few.
http://www.bing.com/images/search?q=plumbing+pipe+clips&FORM=HDRSC2
Creda Heating Towel Rails
Jul 05, 2016 | Home
Wireing a heated towel rail to a permanent switch
A simple on or off switch, connect power to 1 screw and rail to the other screw. A dimmer or reostat is the same. Select amp rating of the switch higher than the amp draw of the rail.
Dec 07, 2013 | Electrical Supplies
The display has gone blank on T1033 . the only way to get towel rack to work is by pressing the on/off selector
1) Try resetting timer. Aube/Honeywell TI033 7-day 2400watt timer cannot be exposed to temperatures below freezing, even though manual says -5 F. High temperature range is 122 F .
This timer has 3-year limited warranty. Internal battery is non-replaceable.
http://waterheatertimer.org/Aube-timers-and-manuals.html
2) There is no other programmable in-wall timer that can handle 2400 watts without using contactor.
3) Replace with GE 15132 timer for cold environments, and single-pole or 3-way operation: Use contactor for heavy loads.
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump22-28.jpg
4) Add comment as needed
Dec 28, 2012 | Hardware & Accessories
Smiths Timer ET 07
These are the original instructions. Unfortunately Fixya won't allow higher resolution images.
Dec 19, 2012 | Hardware & Accessories
How to set up a time guard ETU2000 timer
Looking for some help with my TimeGuard ETU2000. I'm not getting any hot water whatsoever, tried boost, reset, resetting timed hot water all that but still no hot water, in fact I kept the main switch button so that it heats up water but no joy till date. Please advice anybody out there..
Nov 08, 2010 | Heating & Cooling
My Timeguard ETU2000 timer sometimes seems to get lost and continually switches on/off. This seems to happen after I use the 1hr or 2hr or continuous on functions. Does anyone know how to reset this...
hi there im having problems with my timer imersion and came here looking for awnser of my own lol any hows just seen your question and if you want to reset the unit completly ive found that press and hold the black setting button in at the same time hold the white program button in so basic hold both buttons in at the same time watch the screen display and you will see it display all the digit featuers when you see that release and its reset hope this helps you
regards mike
Sep 18, 2009 | Hardware & Accessories
Dryer is working but not heating up
check for power at the wall it should be 240 volts. if that is OK then you need to get a heating element. the towel setting is an automatic cucle if the cloths are not drying then it wont advance the cycle
Dec 10, 2008 | Whirlpool LER5636P Electric Dryer
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
