Question about Pulsar Watches
Pulsar PC3011 battery
What is the battery replacement # for a pulsar n944 6a00 ?
BATTERY CHANGE The miniature battery SEIKO SR927W which powers your watch should last approximately 2 years. However, because the battery is inserted at the factory, its actual life once in your possession may be less than the specified period.
Mar 24, 2016 | Pulsar Watches
What type of battery does a Pulsar pxh227 watch take?
The Pulsar pxh227 uses a sr920sw silver oxide battery. An AG3 alkaline battery will also work, is cheaper, but will not last as long as the sr920sw.
Oct 12, 2013 | Pulsar PXH227 Wrist Watch
Which watch battery fit my Pulsar?
372 or 373, they are interchangeable. It was listed under Seiko and not Pulsar.... the key model # is the vx43, the rest wasn't used. My source: MAXELL 373 SR916SW 1 Battery Official OEM 372 373
Feb 28, 2012 | Seiko Watches
My mother has a fifteen year old Pulsar Y480-5730 that doesn't run anymore. Any recommendations?
Did you check the watch battery? Pulsar watches run a long time! If a new battery does not start it up you can take a can of air and just squirt a little in the area where the battery goes (very gently) to blow out any dirt then install the battery and put back on. If it is still not working you need to take it to your local jewelry store to have an estimate for repair, usually 60.00 to 80.00. I hope this helps!
Sep 18, 2011 | Pulsar Watches
Crystal feel out and is lost, what course do we take?
You can mail to Pulsar their repair service is called Coserv they are in New Jersey (may not get them right now with bad weather) or your local watch repair!
Aug 29, 2011 | Pulsar PC3011 Wrist Watch
How do I remove links?
You will need a very small screwdriver.
Turn the watch on its side. Firmly grasp the bracelet in the area of the link you wish to remove. Insert the 1-mm screwdriver tip into the slot on the screw head. While applying gentel downward pressure on the screwdriver, turn the screwdriver counter clockwise to loosen the screw. Continue to turn in a counter clockwise motion until you can feel that the screw is completely free turing. Step 2. disassembly2.gif Grasp the end of the screw with the tip of a pair of tweezers and remove the screw from the link. Set the screw in a safe place for reassembly. Step 3. disassembly3.gif Once the screw is removed, the link will come apart. Repeat this for as many links as necessary. If removing an uneven number of links, remove the greater amount of links from the 6:00 side.
Aug 20, 2010 | Pulsar PC3011 Wrist Watch
Pulsar chrono hand alignment
mcdedevito75 here, Return to the watch rep[air that installed the battery for adjustmaet.
Jul 03, 2010 | Seiko Pulsar watch
How to replace the battery
I don't know if this is helpful or not, but Walmart will often replace batteries at their jewelry counter for free. You just have to pay for the battery. Hope this helps.
Mar 12, 2010 | Pulsar PC3011 Wrist Watch
Watches Logo
13 people viewed this question
Top Pulsar Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Pulsar Watch Expert? Answer questions, earn points and help others
