Question about Dell UltraSharp 2407WFP 24" LCD Monitor
Delldell2407wfpb monitor does not work
Screen does not work
ASUS VT207 Touch Screen Monitor - Touch is not functioning properly
install your monitor drivers and update the windows it will works
Apr 20, 2015 | ASUS Computers & Internet
Does not turn on
Hello
With any monitor, check the following to determine if the issue is MONITOR related or COMPUTER related.
1. Verify the monitor is receiving power - use a known good power outlet and plug it into the monitor
2. Samsung monitors have a light on the power button - are you getting any color light from this? Orange means it is in "stand by" mode and is waiting for the PC to send it a signal. Green means the monitor is getting a signal from the PC and the monitor is on.
3. With the monitor on, press the buttons on the monitor to bring up the OSD (on screen display) that changes the monitor settings. If you have a green light on the power button and press one of these buttons (AUTO works best), this will display the monitor adjustment options on the screen.
If you see the on screen adjustments, your monitor is working and the issue may be with your PC. Move the monitor to another PC and verify the monitor is working correctly.
IF you don't see anything on the screen and the power light is green, the monitor has failed.
This could be the lights that illuminate the screen have failed (something that happened to my Samsung Syncmaster monitors after about 6 years of use) or the screen has stopped functioning. In either case, replacement parts are hard to find and a monitor swap is likely.
Nov 03, 2013 | Samsung SyncMaster S22B150N - LED monitor...
My Brother is trying to connect to HP Pavillion XT914. A friend connected her flat screen to his pavillion to help him delete unwanted files and he can't get the monitor to work any more. How do we get his...
It might be that the screen resolution set on the pc is too high for the monitor to display.
try hooking up the flat panel monitor again. (CRTs can have a flat screen as well)
lower the screen resolution to 1024 X 768 pixels click save.
hook up the other monitor to see if that was the problem.
If you can get the monitors menu to come up on the monitor try setting it to factory defaults.
If no luck, does the monitor work on another PC?
Let me know if this helps you or not.
Thank you
Feb 05, 2011 | HP Compaq FS7600 17" CRT Monitor
Screen is black.
Please shine a flashlight on the monitor screen.
If you see a dim image on the screen the back light needs to be replaced.
If it still shows black try another data cable from the monitor to the computer
If that still did not work as the machine is turned on remove the data cable connector from the computer. Check the monitor screen to see if it says no signal. If it does not the LCD screen on the monitor needs to be replaced. If it does the computers graphics card needs to be replaced.
Sep 07, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor screens blanks a few seconds after I switch on computer
Took the cable connecting the monitor to the computer and reversed it, this seems to have worked!
Dec 21, 2008 | Sony SDM-S74 17" LCD Monitor
Dell monitor problem
Try pressing Fn + F8 keys to toggle the screen image.
Nov 30, 2008 | Dell E176FP 17" LCD Monitor
MAC screen doesnt fill Samsung Monitor
Often there is an auto correct button on the monitor, if not them press them menu button and navigate to find horizontal size. If neither of those work you might try taking apart the monitor and reseating the video cable to the monitor.
Jun 08, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
Alun Cox
