Question about Brother ML-100 Typewriter
Typewriter does not correct
When i push correct the ribbon does not raise up to correct what i have typed
  • 43 Answers
There is a cam cluster under the ribbon plate that has to move over when you hit the correction key this lifts the correction tape, make sure the lift is not working and that the correction tape is old, and just does not lift off, have seen that...
Posted on May 08, 2014
Soulvisitor
  • 1113 Answers
SOURCE: correction ribbon
see http://www.fixya.com/support/t219379-correction_ribbon
Posted on Oct 27, 2007
  • 3594 Answers
SOURCE: Correction Ribbon
If the machine is making allthe correction movements, be sure the correction tape is installed with the dull side facing the paper.
DickyO
Posted on Jan 05, 2008
squipps
  • 204 Answers
SOURCE: typewriter won't type letters
HI.. the hammer solenoid may be faulty..it should make a typing sound when you hit a key.( the printhammer moved and strikes the printwheel) or when you changed ribbons you might have unlatched the printwheel..there is a lever you press to relatch it until it "clicks"
If not that then make sure the ribbon is seated correctly, that it is between the printwheel and the black roller.Also visually inspect the ribbon so it is not caught in the printwheel.
Posted on Feb 06, 2008
  • 99 Answers
SOURCE: Brother Typewriter
Dear Chruchbells,
You may be right about typing on the coreection riboon. Tell your friend to take out the ribbon cartridge and reinsert it. It needs to click all the way down, or else if it is at the ink cartridge level, it will type white!
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=10
Posted on Feb 07, 2008
SOURCE: Changed Ribbon
I bought the ribbon and it did not work so I took it back got another
one and it still will not type
Please help
Posted on Sep 23, 2008
IBM Wheelwriter 2, the bottom half of the letters are not printing. It is not the ribbon because I have changed it out.
Two things come to mind for this problem. First try pushing down firmly on both ends of the black rubber platen roller. Sometimes the black plastic latch on either side may break causing one side of the roller to lift up causing partial print. The other possibility is the ribbon is not lifting correctly. A technician can adjust the ribbon lift. After typing a few letters, take the ribbon out and look at the letters on the ribbon.Are they in the middle of the ribbon or are they at the top or bottom of the ribbon? middle of ribbon is correct.
Mar 01, 2016 | IBM Lexmark Personal Wheelwriter 2...
The ribbon won't advance
It sure sounds like something is interfering with the correction tape. Look for debris in that area.
DickyO
Oct 02, 2014 | IBM Wheelwriter 30 Typewriter
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
After pressing correction key i could not type again .no ink is there .
During correction the lift-off tape is raised. Please check that it goes down and does not interfere with the printing ribbon.
Removing and reinstalling both is probably the best way.
Apr 01, 2011 | Olympia Standard 300 Typewriter
Correction bar not working. When I type in a word and hit correct, instead of lifting the lettter off the paper it types the letter I typed in bold. Is there a button I can push to correct this from...
The correction tape may be installed wrong, or it may be a tacky L/o that will stick nand not raise up..
You can find a manual at BROTHER.COM, click on support.
DickyO
Sep 02, 2010 | Brother EM-530 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
I put in new Brother ribbon - won't type. I hit code reset.
MAKE SURE THE RIBBON IS INSTALLED CORRECTLY AND IS BETWEEN THE TWO METAL "FINGERS" AND THE CARDHOLDER AND THE PRINTWHEEL IS LOCKED INTO PLACE (JUST PUSH FORWARD ON THE BLACK LEVER TO THE RIGHT OF THE PRINTHAMMER
Dec 19, 2008 | Brother GX-6750 Typewriter
Swintec 7040 typewriter ribbon feed.
The typewriter is supposed to automatically adjust itself to the type of ribbon you have installed. Have you tried a different ribbon?
Feb 11, 2008 | Swintec 7040 Typewriter
Brother AX-450 Electronic typewriter
Hellooo.
2 thing come to mind you may check.
First check the ribbon cartridge to see if it is empty..These are usually a one time ribbon...and has to be replaced when empty.
2nd make sure the cartridge is snapped in properly and seated, and also the printwheel lever must be snapped (pushed forward) in order for everything to be aligned. if the typewriter has a correction tape (white or clear) make sure it is not interfering with the ribbon.
Lastly the ribbon drive may be broken or out of adjustment. a minor repair.
Hope this helps...
Squipps
Jan 08, 2008 | Brother EM-430 Typewriter
Correction ribbon
make it sure that the correcting ribbon correct insert to the guide of the ribbon push it then you feel lock , test correcting not jumping ribbon case , then ok.
Dec 11, 2007 | Brother GX-6750 Typewriter
Brother ML-100 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
