Question about Alesis DM10 (Module) High Definition Drum Module W/Dynamic Articulation
DM10 BASS DRUM PROBLEM
INTERMITANT AND SOMETIMES NO DRUM SOUND
I want to build an amp that will deliver a bass drum sound for the stomp box I built.
As a 40 year guitarist and repair technician I had to laugh at this until I thought about my younger days of starting out. What I see here is that you made a momentary trigger out of a stomp box that apparently had problems, that you think you can build an electronic bass drum to play it with. Is this correct? See, the amp only gives a bass drum sound ONLY if a bass drum sound goes through it. Amps only provide audio power to the input signal. Where to get you bass drum sound is what you need to find. I believe you are thinking of a sample. A sample is an actual recorded sound of a bass drum that you could actually trigger by stepping on that button. You could find this on most cheaper casio, yamaha, emerson, radioshack, keyboards or drumpads or any of those amateur toys. Most of them allow a trigger pedal to be plugged into it and operational. Now, after you find something with a bass drum sample that you can trigger with your pedal, that device should allow you to plug it into an amp to amplify it. I hope I didn't confuse you much and had a close perspective of what you tried to describe. Please let me know if I can help further.
Mar 10, 2014 | Music
No sound from bass drum
MAKE SURE YOU DIDNT TURN OFF THE TINY SWITCH IN THE BACK OF THE MODUELE
Jan 04, 2013 | Alesis DM6 Electronic Drum Set
I have a dm10 and I keep getting
UNPLUG A TRIGGER. PLUG BACK IN AND HIT O.K.
Sep 29, 2012 | Alesis DM10 (Module) High Definition Drum...
Every time i hit the bass drum i hear a click along with the bass drum sound...i cant figure out where it is coming from
Unplug all the other triggers and see if it is in the mechanics of the kick mechanism. If not, then one at a time plug in the other triggers till you find one that is causing it. Could even be the bass when amplified is triggerin lightly the rim of the snare for instance.
Sep 17, 2011 | Roland KD7 Drum Controller
I need help my new dm10 mod comes up with calibration fail when I turn it on even with nothing plugged into it. I have updated the firmware it just wont talk to the kit at all
you have to make sure the red crash 1 is on the cymbal w the choke zone on it and plugged into crash one on the module. crash 2 goes in the cymbal w no choke and plugs into perc 2 on the module. also make sure the ride zones are plugged in to the corresponding zone on the module. bottom line double check all connections and reference the setup guide if u still have it. i had the same issue.
Jul 22, 2011 | Alesis DM10 (Module) High Definition Drum...
Hi, I have a Ludwig Classic Maple drum comprising: Bd 16x24, Sr 5x14 , Tt 7x10, Tt 8x12 , Ft 14x14 , Ft 16x16 . I am very happy with the sound of this drum, very powerful, resonant, and easy tuning, I have...
Here I've listed valuable reference information on bass drum tuning and achieving the lowest pitch possible. Some things are trial and error but once you fully familiarize yourself with drum tuning you should be able to achieve the sound you want. Hope this helps.
Kick Drum Tuninghttp://home.earthlink.net/~prof.sound/id6.html
Bass Drum Tuning Lesson http://www.drummerconnection.com/drumlessons/youtube/46667-bob-gatzen-bass-drum-tuning-lesson
Apr 05, 2011 | Ludwig Classic Maple Power Drum Set Shell...
My kick sound has died out of the kit, when i press the button there isnt a sound so i assume it doesnt have anything to do with the cables or actual bass drum pad. any ideas?
My guess would be something faulty with the cable connector to the kick pad.
Source the faulty link by reconnecting the pad so that:
1. A tom pad triggers the bass drums sound 2. The kick pad triggers a tom sound 3. Don't use cable you use with the kick when searching for the fault.
This should tell you whether it's the pad, the bass drum channel or the cable that is at fault.
Hope that helps!
Mar 03, 2011 | DDrum Kit
I have a Alesis DM10 pro kit and both the 8" drums
They show the make up of this on You Tube...search for DM10 there.
Feb 08, 2011 | Alesis DMPad 8" Dual-Zone Drum Pad
When i strike the Bass Drum pedal, i sometimes get a cymbal noise also coming out of the kit. Its not the crash or ride cymbal i can hear, as when i look at the display, i can see a little bar to the right...
First thing to check is if the vibrations of the bass drum amplified MIGHT be triggering the cymbal pickup. Damp the cymbal pad with your hand and see if it still does it. If not, then shield the drumset from the amplified output.
If this does not prevent the problem look for a grounding problem of the triggers.
Sep 19, 2010 | Yamaha DTXplorer 5 Electronic Drum Set
Yamaha DTXtreme IIS Drum Moduel repair
Listen to the output with headphones to check for noise.
OFTEN the output of a drum machine is CORRUPTED by an inadequate sound system. The waveforms generated by a drum machine tax the sound systems. A bass drum output can drive the speaker cone such that it goes beyond the linear range that the speaker and amplifier can handle and this appears as "noise". The noise may sound like a buzz or totally break up.
Turn the volume down and see if EXACTLY the same noise appears at low levels. If not, then saturation of the amp and speaker is likely. Continued use while it is doing that will often destroy the speaker.
Nov 28, 2009 | Yamaha Music
Alesis DM10 (Module) High Definition Drum Module W/Dynamic Articulation Logo
21 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
