Question about Ricoh 406852 Aficio Sp 5210sf Mono Laser P / S / C / F Enet 1200x600 5
Touch screen adjust ricoh 5210
How to calibrate touch screen
2 Suggested Answers
SOURCE: While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 te
I think you'll have to run a factory reset.
However, I cannot find any way of carrying this out. You'll need to contact Ricoh or their dealers, I'm afraid.
Posted on Feb 18, 2015
Ricoh aficio MP c3000 touch screen: displays, printer reacts to physicly pressed keys (number of copies changes on the screen etc), prints scans but does not react to touching the screen
the touch screen might be out of order, or if just when yo press something specific , as example the tray 1, an it react as you pressed something else then the touch screen need calibration. you can enter the calibration process by pressing in this right order the next buttons. first press once the yellow key then press 1993 and then press the red stop key 5 times and the lest 5th hold it for 10 seconds, after you release it press the blue number key pad 1 and then adjust the screen as it request the machine from you one order then other till the end for more info please write more info..
Oct 02, 2016 | Ricoh Office Equipment & Supplies
How to reset SC544 for Ricoh MPC 3000 when the keyboard is faulty
Maybe TOUCH panel doesn't work.
Try to calibrate it:
Yellow -->1-->9-->9-->3--> Press Stop(red one) 5 times.
1 - Touch screen adjustment!!! Follow instructions on the screen.
After calibrating exit and try again to enter service mode.
Good luck
Prepare to by new TOUCH Panel
Pifonski
Sep 30, 2015 | Ricoh Aficio Office Equipment & Supplies
While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 test...
Feb 18, 2015 | Ricoh Office Equipment & Supplies
Touch screen blocked
The touch screen could have lost its calibration, but there is a good chance that it is bad, and needs to be replaced. To calibrate it, push the yellow clear modes key, then the numbers 1, 9, 9, 3, then push the red "Clear / Stop" key 5 times, and choose number one. Follow the prompts. Use a stylus or other dull pointed item. If you don't get a response, you need a new touch screen.
May 22, 2014 | Ricoh Aficio 450 Copier
Touch screen not responding
Which model of Ricoh are we talking about here? If touch screen is not responding before replacement, re-calibrate touch screen or replace it. I can help you with the calibration code if you require. If the touch screen is not responding after replacement, check whether the replacement lcd display panel was installed reverse as the connectors will not have contact.
Mar 12, 2014 | Ricoh Office Equipment & Supplies
Touch screen calibration
Press the keys listed below, please note you need to press the Clear/Stop key 5 times. The screen will change after entering the keys and touch screen calibration will be option number 1. The calibration will consist of pressing a couple of small circles on the screen.
Clear Modes->1-9-9-3->Clear/Stop(5 times)
or
Reset->1-9-9-3->Stop(5 times)
Feb 17, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
Touch screen
After clearing the memory,or if the touch panel detection function is not working correctly,follow this procedure to calibrate the touch screen.Press the yellow reset key ,press 1993 and press red stop key 5 times to open the self diagnostics menu.On the touch screen press Touch Screen Adjust.Use a pointed tool to press the upper left mark.Press the lower right mark after it appears.Touch a few spots on the touch pannel to confirm that the marker appears exactly where the screen is touched.When you are finished press OK on the scree,touch Exit on the screen to close the self diagnostic menu and save the calibration settings.
Dec 30, 2013 | Ricoh Office Equipment & Supplies
Ricoh Aficio 3025 Copier LCD Touch Screen gets hang after calibration
You need to replace the screen to fix your problem. But if this machine is the model I think it is you need a whole new machine.
Jul 23, 2017 | Ricoh Office Equipment & Supplies
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
Ricoh Aficio 3025 Copier LCD Touch Screen out of Allignment
It's not in service mode, but rather in the 'self diagnostic menu'. Access it as follows:
Press "clear modes", 1 9 9 3, "clear/stop" (5 times).
** Do not try any other adjustments in this mode...only touch screen
please rate me :)
Apr 10, 2009 | Ricoh Office Equipment & Supplies
Ricoh 406852 Aficio Sp 5210sf Mono Laser P / S / C / F Enet 1200x600 5 Logo
26 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
