Question about Hayward Navigator Pool Cleaner
Hayward navigator is a piece of junk.
What is a good replacement for a hayward navigator? my navigator sucks, and constantly needs attention. way too expensive to repair every summer.
    Problem Solver:
  • 7 Answers
I tried to find a better one last summer and bought the "Baracuda" (there are several syles and brands like this). It was absolutely useless. It didn't have any moving parts to wear out, but it didn't clean the pool either. Had to constantly adjust weights on the hose to get it to move around the pool. I finally trashed it and went back to the Navigator. You do have to replace a few parts now and then, but nothing works better from what I've seen and been told by a few pool pro's I've talked to.
Posted on Jul 05, 2009
    Problem Solver:
  • 12 Answers
Try useing THE POOL CLEANER im in the pool industry and switched to these due to always having to perform repairs on the navigator
Posted on Jun 26, 2009
How to clean filter on ladybug
No filter.
You can clean out the internals, just remove the screws from below and then the pieces will remove and then additional screws become visible, until you have everything apart. Keep things organized and all will go back nicely.
Take a look at this site listed below...
A lady bug is almost the same unit as a navigator, just has a novelty covering. \
How To Service the Inside of Hayward Navigator Suction Cleaner
Jun 07, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
Why is my navigator cleaning in reverse?
Check the positioning of the reverse switch.
Apr 30, 2014 | Hayward Navigator Pool Cleaner
I had a Hayward Pool Vac for 11 years properly maintained, but never had to replace any stainless steel part. Thus, only one year ago, I replaced it with a late model Navigator. It stopped moving two...
Hayward navigators have a 2 year warranty on their cleaners. The springs, as of now, are not replaceable so you would need to replace the pod kit. This is under warranty.
May 02, 2011 | Hayward Navigator Pool Cleaner
My Navigator Pro is 3 months old. The pads and wings are in good shape. I have plenty of suction, but the Navigator won't move. I didn't see anything stuck, but the rocking feet will not move. I thought...
You should be able to move them with your hands. If you can't, the only thing I can think of is that something is stuck in one or both of them. Remove the pods(the pieces on the sides) and clean them up including where they go into the body. The cleaner is too new to need any repair. Be sure when you put them back on that you tighten the screws all the way.
www.cpo2go.com
Nov 21, 2010 | Hayward Navigator Pool Cleaner
My ****** sucks but it won't go forward. i had all gears and gear box replaced, shoes, wings, could it be the front flap? when i take off the front flap it moves forward. we borrowed a used loaner from the...
You can try "A" frames and a new paddle wheel. If these are bad the suction can be real good and you can get some movement out of the cleaner but as soon as it get's a load on it, it will stop.
Oct 10, 2010 | Hayward Navigator Pool Cleaner
My hayward navigator just moves in a circle. I picked up the navigator and saw that one of the paddles is not moving. When i pressed down on the paddle that was not moving it starts moving but as soon as I...
It wouldn't hurt to replace the pods (paddles). Also, the wings, flaps, A-frame, turbine, feet(shoes) and the gearbox. All of these things wear and should be done about every 12-18 months, as needed. Before you do any of this, though, try tightening the screw on the pod that's not working. These screws need to be very tight.
www.cpo2go.com
May 20, 2010 | Hayward Navigator Pool Cleaner
The pool navigator has very low pressure, why?
if you have good flow coming from your jets then make sure that youve narrowed down what the pump is pulling... i.e: shut off some valves like your main drain and skimmer line if possible so the vacuum gets more attention from the pump....
if you have bad flow ... try cleaning your filter
Apr 11, 2010 | Hayward Navigator Pool Cleaner
I need to know how often and for how long should I use my hayward navigator in order to keep it in good conditions
you can probably run it for four hours a day, every other day or every three days depending on how much dirt and debris are introduced to the pool. that should increase it's service life considerably.
Aug 04, 2009 | Hayward Navigator Pool Cleaner
Hayward navigator model #925CS keeps tipping on it's side.
Mine did the exact same thing. It's the hose that connects to the navigator. Replace it!! Problem solved.
The Header Hose becomes brittle and won't bend properly which causes the Navigator to tip on the side or backwards.
My advise is to replace all the hoses. If the header hose is bad so are the rest of them.
Apr 01, 2009 | Hayward Navigator Pool Cleaner
Hayward Navigator Pool Cleaner Logo
364 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
