Question about FBT Promaxx 14 Speaker
Distorted sound noisy when no input present and distorted when driven. Seems to limit when increasing volume control.
Low volume on created DVD
Unlike ripping CDs, ripping DVDs poses many challenges for the average user.
Because you need to get audio and video and need to get them synced correctly problems with the final version frequently arise.
One common problem is that the volume is too low.
The solution might seem to be to simply turn up the speakers, but the sound of a low-volume movie cranked up can crackle or distort. Instead, you increase your DVD rip volume by changing it before you begin the rip process.
Increase DVD rip volume with iSofter DVD Rip (see Below).
http://www.dvd-tool.com/dvd-ripper/faq.html
With this program, a window called "Input Settings" allows you to control the volume before you begin. After the DVD is in the computer, you just use the "Volume" slider to increase the output volume. As of November 2010, the program costs $34.95.
Try Aimersoft DVD Ripper (see Below).
http://www.youtubetoipod.biz/software/aimersoft-dvd-ripper.html
After inserting the disc, you simply click "Load DVD" and wait for it to load
(this could take a few minutes).
The "Settings" button presents a volume slider similar to iSofter's.
Push it to the right to increase the output volume.
As of November 2010, the program costs $35.
The free dvd::rip program offers the most customizable settings for the advanced user
(see Below).
http://www.exit1.org/dvdrip/
Not only can you increase the output volume with a volume slider, you can also compress the sound as well.
This is useful for movies with both loud and quiet parts (such as action movies). It reduces the volume difference so you don't have to reach for the remote every five minutes.
Jun 27, 2013 | Corel 9900-65295-00 Pinnacle Studio 16...
The speakers work fine apart from the sub component has lost all volume u can hear it very faintly if u turn the volume to full and the bass control to max. I've taken the sub apart to some extent...
Appears that the map powering the sub woofer is fubar. Those amps take a beating usually from being over driven. Transistors are not like tubes that will just reach a limit, distort, and stay there. You push a transistor and it will self destruct since it knows no limits ala evel knevil.
Sep 20, 2017 | Creative Labs i-Trigue 3400 Computer...
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
Distorted sound especially when I try to increase volume
Use the input to be fed using an external audio feed from a source and if there is distortion in the output then the output section is faulty.
If not the output is working fine and the premap section can be faulty.
Aug 04, 2011 | Wharfedale Televison & Video
Some of my records sound distorted in playback others play fine it seems
This could be a defective cartridge or a bad belt. It all depends upon the type of distortion that is present. Poor speed control can be difficult to hear with speech but very noticable in music. With low volume sources, poor quality may not be as noticable and hide cartridge problems. Can you please update this with a description of the distortion as well as the model number?
Thanks,
Dan
Oct 05, 2010 | Technics Audio Players & Recorders
Crate bass amp bt220 limit led is flashing with the volume only at half
You can reach the limiting IRRESPECTIVE of where the volume control is set when you have a guitar or other source that has HIGH output.
Guitars that have battery in them with internal amplifiers are an example of a high output guitar. Plain inductive pickups may require the volume control to be set at say 70% to reach limiting.
Please NOTE that the volume control is NOT linear, but is an "audio taper".
Limiting means you are probably driving it too hard. Many learn the hard way when speakers and thee power amp fail.
When the cone is driven too far beyond the pole pieces of the magnet, then the IMPEDANCE of the speaker becomes relatively low and can damage the power amp. The limiter tries to prevent this by sensing the current and or voltage and will back off the gain internally. This causes distortion when it happens.
Dec 14, 2009 | Crate Music
The volume of my mp3 player sony E436F is too much low. Can I to high...??? Is there any solution???
Hi rockgfr,
The first way to increase the volume is of course by the volume control on the right hand side of the player. If even at the highest limit (30) provided by this control, the volume seems low, then go to Settings --> Common Settings --> AVLS. The volume limit is probably on, so you can try putting it off and see if you can increase the volume further. Failing these methods, you can always use software like MP3Gain to raise the volume of your tracks.
Nov 04, 2009 | Sony NWZ-E436F MP3 Player
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Z-2300 noisy speaker
ur speaker is bad probebly torn membrane try replacing it (or disconnecting) this speaker there is a special kind of glue for membranes .... try it good luck windman
Oct 26, 2005 | Logitech Z-2300 Computer Speakers
FBT Promaxx 14 Speaker Logo
66 people viewed this question
Top FBT Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a FBT Electrical Supply Expert? Answer questions, earn points and help others
