Question about JUMP START SYSTEM
WILL NOT CHARGE
HAVE CHARGED IT FOR MORE THEN 5 HOURS LIGHT COMES ON BUT WILL NOT JUMP ANYTHING.
    Master:
  • 710 Answers
It needs a new battery.
Posted on Sep 01, 2014
Blinking yellow light on charger when plugged in Why is this?
depending on what you are charging it could mean the battery is extremely flat and it will flash until it has charged it enough to be registered for charge or it's to flat and it cannot be charged, depending on the battery they can be jump started with another battery, but if the battery is damaged it can also flash. leave it on charge for a few hours if no change then, it would be one othe the problems i have listed.
Jun 28, 2017 | Health & Beauty
Charging/Charged Indicators
I don't know what model of radio, but here is what I would try: pull the batteries and charge them on the charger by themselves if your charger allows this. The lights, well, some manufacturers just miss the boat. Especially on low end or "beginner" radios. I have one brand I can insert with NO BATTERY and the light comes on. Talk about useless. Charge times vary by size of battery and charger output, minimum is 3 hours, 12 hours much more likely but I see a lot at 5-7 hours. Hope this helps, model and brand helps always.
Dec 12, 2015 | Walkie Talkies Radio Communications
Why did weed eater just stop working?
Take note: The battery pack will not reach full charge capacity on the first few charges. The break-in period requires 4 to 5 charging cycles, where the battery pack is completely discharged ( no motor sound or tool motion) and then fully recharged. During the break-in period the battery needs to be charged 5 or more hours continuously. The green LED light on the charger will come on in 3-5 hours,this is normal, Continue to leave the battery pack chargingvfor a total of 5 hours or more. After the break-in period, a full recharge is indicated on the charger when the green LED light is lit. Note: Do not charge battery in areas lower than 50 degrees or higher than 80 degrees. Looks like this will need to be charged in the house. I found all this information on page 14 in your manual.
Jul 18, 2015 | Garden
Where do I plug in the cord to start charging the jump starter (Black & amp; Sage ) 900 peak ,350
Google for an owner's manual. I can't find anything on this jump starter, but first they need to be charged, usually by plugging into a wall socket for 12-24 hours. Then plug into the cigarette lighter for 10 min or so to give the car battery a boost charge.
Dec 04, 2014 | Cars & Trucks
My jumpstart system does not charge past level two. (only the second light comes on.) I have charged it for 48 hours and nothing. The compressor does not come on either.
The battery is probably too old to hold a charge. http://www.baccusglobal.com/bd/manuals/NEW%20MANUALS%20FOR%20WEB/VEC012POB%20MANUAL.pdf
Aug 14, 2011 | JUMP START SYSTEM
When I plug in the adapter to the charge the consol the orange light lit. The light does not turn off even after 13 hours of charge. After 13 hours when I want to use it, the red light comes on not the...
Hello there. You may need to replace your battery pack, as leaving it charged for over 4 hours can lead to "overcharging" a condition which can dramatically shorten your battery packs lifespan and charge retention.
Also, be sure to charge your console while the device is turned off. Although you may charge it while it is powered on, it will take longer.
As stated, be sure not to leave the system on charge for more than 5-6 hours, as this can damage the battery and is liable to cause battery leakage, burning, or overheating.
Battery life is largely dependent on the game being played - some games can give you up to 10 hours of battery life, though the real-world estimate is really more like 5-7 hours of constant use before you'll need to recharge.
I hope this helps you. -
Frankie.
May 11, 2011 | Nintendo DS Lite Console
I purchased a new battery, installed it and plugged in cord to charge. The charge light came on, it was on charge for about ten hour, This overnight that I charged the battery, the charge light was out the...
Some units will charge with the light on and when it reaches full capacity the light goes off preventing overcharging the battery. Now! you mentioned that the battery had charged, how long did the battery run? "should be around 2 hours" If you find the light comes back on to recharge the battery then this probably normal. But if the battery is ready to be charged and no light comes on, then it indicates the charging circuits in the motherboard is not working.
Jan 14, 2011 | Compaq Armada M700 Notebook
I have a audiovox dvd player model D1998PK. I need to know how to tell when the battery is charged.
1. A blinking light indicates that the battery is not charging.
2. The steady light goes out (or turns green) when the battery is charged.
3. 6 to 8 hours for the initial charge.
4. Charging time after the initial charge depends on the length of time the battery was used and will increase over time as the battery gets older.
5. 2.25 hours of play time
Aug 23, 2008 | Audio Players & Recorders
RCA prov712 battery will only last 5 minutes
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
Dec 19, 2006 | RCA PROV712 Camcorder
JUMP START SYSTEM Logo
64 people viewed this question
Top Vector Vehicle Parts & Accessories Experts
Lawrence Oravetz
Vernon Taylor
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
