Question about SIERRA MARINE MP39090 - Ignition Switch
Need a wire diagram to connect a new mp39090 to a 6 pin Pollack switch
Afraid to hook it up wrong
Bad connection on 5 pin mic jack on realistic trc-469. Wiggle it and it'll work. But how does it come out ? Have a new 4 pin to replace it with. Can't find the break.
With the CB radio off & not connected to power, check or have a friend check the contact points, at each end with a Volt/Ohm Meter.
Oct 10, 2016 | Radio Communications
How to connect front pannel ak32 motherboard?
Here is the pinout of the front panel connector.
aaxnqfcgbhsmaaaaaelftksuqmcc
The power switch connects to the PWR PT pins. The speaker hooks to the SPEAK pins (only the outer pins actually used). The HDD LED connector hooks to the HLED pins. There is usually one red and one white wire. The RED wire goes to the "+" pin. The power LED wires hook to the PLED Pins. There is usually a green and a white wire. The GREEN sire goes to the "+" pin. The GLED pins are for the SLEEP switch if you case has one. The RST pins are for the RESET switch wires (if your case has one). Hope that helps
Jul 30, 2014 | Shuttle AK32 Motherboard
Do you have switch schematics
No diagram available, but wiring is as follows: PPL/BLU wire connects power from FUSE 21 in the interior fuse panel; Pin 1 - WHT/PPL to RF window switch; Pin 2 - YEL/PPL to RF window switch; Pin 3 - WHT to RR window switch; Pin 4 - YEL to RR window switch; Pin 5 - N/C; Pin 6 - WHT to LF window motor; Pin 7 - YEL/GRN to one touch down window relay; Pin 8 - WHT/BLU to LR window switch; Pin 9 - YEL/BLU to LR window switch; Pin 10 - ORG/YEL to interior lights system. A second PPL/BLU wire connects the rear cut off switch to the left and right rear window switches.
Jun 21, 2014 | Drills
Replaced clutch in 2006 kia spectra
if you connect a positive wire to ground , rest assured that you will be looking at a new harness
get a schematic diagram from a workshop manual and do the job properly
Aug 17, 2017 | 2006 Kia Spectra
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
Jun 30, 2012 | E-Machines Computers & Internet
Hooking up trailer lights i no longer have marker lights, running lights or dash lights. headlights 4 ways brake and signals all work any sudestions?
Depending on what connector you are using, here is a link to the wiring diagrams:
http://www.etrailer.com/faq-wiring.aspx
You may have to use an OHM meter to test the leads at the tow vehicle side to verify correct placement. Good ground is essential too.
Jan 25, 2011 | Dodge Dakota Cars & Trucks
Issues with Schumacher Battery Charger SE-82-6 - Schumacher 3 Position Slide Switch (8 pins) - Does anyone know how the wires hook-up to to the pins on the back of the switch?
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
Nov 27, 2010 | Schumacher & Fast Charge Starter Charger
Need wiring for on-off switch
Hi Joe. Typically the switch interrupts the hot wire, which is black. Therefore, two black wires are connected to the two screws on the switch. Look in the area where you see the one black wire and you should find a second black wire. Connect each of the to the switch and you will be switching [controlling] the hot [black] wire.
Dec 10, 2009 | Lakewood 7101 Oil Filled Radiator Heater
1999 dodge ram 3500 cut factory trailer wiring
Check out this link www.dodgeram.org/tech/mods/electric/trailer_wire.htm
Jun 27, 2009 | 1999 Dodge Ram
I get no output from an LC-350 ATX BIAS SUPPLY
DOES THE SWITCH HAVE 4 REMOVABLE CONNECTION, IF SO THE POWER SUPPLY MAYBE HOOKED UP WRONG, REMOVE ALL WIRES AND CONNECTION FROM THE MOTHERBOARD LEAVE ONLY THE POWER CONNECTION AND THE VEDIO MONITOR CABLE, ADD ONE CONNECTION AT A TIME AND TURN SYSTEM OFF AND ON UNTIL YOU HAVE A PROBLEM AND I KNOW IT IS ALOT OF WORK THAT WHY YOU PAY SO MUCH FOR A COMPUTER EXPERT TO LOOK AT YOU COMPUTER DESKTOP OR LABTOP.
CANDYMANGANDY
Jan 26, 2009 | Computers & Internet
SIERRA MARINE MP39090 - Ignition Switch Logo
85 people viewed this question
Top SIERRA MARINE Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a SIERRA MARINE Boating Expert? Answer questions, earn points and help others
