Question about E-Machines -T1840-CELERON-1.8GHz,40GB Desktop Computer System (1000000127)
No power someone took my hard drive out,and with out me knowing this i plugged my computer in and now i cant get any power even after i put my hard drive back in.
  • wildlflwr218 Nov 28, 2007
    My computer stopped working. I took it to the Geek Squad....they said it was the power supply. I bought a new unit...(power suppy)....I hooked it all up and I turned it all on...and it worked ONCE!!! Now that I have put it all back together it isnt working again!!! GRRRRRRRRR....I am not very computer savvy...but what happened???? the comuter is a Compaq Presario SR1030 NX
    Scholar:
  • 90 Answers
Hate to say it. But down at my shop, we have repaired a good 200+ eMachines in the last two years... all with the same ailments.
Usually what we find, is a bad power supply. That's only the first part.... in most cases the mainboard is damaged as well and needs to be replaced.
If you look at your power supply, it is probably a Bestec brand. While you have the cover off, look over the mainboard with a flashlight. You may find a blown ITE chip, or even some hot spots or small burn spots on the southbridge chip. Which is located usually towards the bottom right side of the board if your point of view is with the computer sitting upright. It will be about one inch square in size.
If you have a space power supply, or know someone with one, you can try that. We've not had much luck replacing just the power supply. In a few rare cases it solved the problem. But in most, a motherboard replacement was in order as well.
Best we can figure, the power supply fails and takes the mainboard with it. The only commonality among each one, was the Bestec power supply. Since some of these were Intel based and some were AMD based.
Posted on Oct 31, 2007
I have a WD MyBook Essential and I had it installed on my computer. The next time I went to plug it into the computer all it goes is flash and my computer will no accept that its even plugged in. Its only...
Unplug the drive from the computer.
Remove the power cord from the drive, wait 20 seconds.
Plug power cord back into drive.
Restart your computer.
Plug drive back into USB port.
Should work now.
Best if you can to use direct port on computer and not multiport adapter...
Jun 29, 2011 | Western Digital My Book Essential Edition...
When i plug it in to usb drive blue light flashes only once but it is not shown on my list of devices on my pc and i cant veiw photos on it
The power supply on the drive has failed. What you can do is take it out of the enclosure and put it in a new hard drive enclosure. I had the same exact problem one time. I took the drive out of the enclosure and intalled it in my computer tower.
Mar 17, 2011 | Seagate (ST625211U-RK) (st625211urk) 2.5...
When I plug it in my Laptop's USB drive doesn't even read it... ,Tomothy
if it has en external power supply check to make sure it's working. You can also try plugging the drive in someone else's computer. If you get the same results the drive is bad.
Mar 21, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I am in Europe and I used the wrong adapter to plug it in, even though it had a power converter built in. And, now it's fried, but I am wondering if the hard drive itself is ok, and I can send it in for...
The drive itself is probably safe. The power circuit board inside is usually toast when this happens. But given the low replacement cost of these external drives, it's probably not worth trying to get it repaired. I don't know if anyone besides the manufacturer would even try to service this. The cost of parts (if they can be obtained at all) and labor might approach that of a new drive. WD may offer a flat-rate repair service (likely they would just put your drive into a new housing), but I've never checked. Their website should list service options.
Your best course might be to remove the drive and check it by hooking it up in your computer. If it survived, order an external drive case from any of many online sources and put the drive into it. Otherwise you haven't wasted any more money on a repair.
Feb 01, 2010 | Western Digital 500GB MyBook Office...
Cant access the external hard drive, heck I cant even find it now. I have all my music and photos on it so it did work.
Hello
A few questions that may confirm problem.
Does your computer seem to know that something is plugged in?
Or does it say that it does not recognize the device?
Well, if the computer actually knows that a device has been plugged in, but you just cannot see the device in my computer, here is how you fix that. Just follow these steps:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your device presented in the schematic below.
Right click on the device and assign a new drive letter.
If your computer states that it does not recognize the device, try plugging it in one of the back USB ports of the computer. Please rate this.
Best regards
Sep 30, 2009 | Western Digital My Book Home Edition 500...
BootBlock BIOS v1.0 BIOS ROM checksum error
Kevin, when you do get this going it is going to be a beast.Nice choices on the hardware. It appears that you are getting text in the bios menu and that is a real good sign. One bit of text you typed might be a clue." You typed Detecting floppy drive A media . . .
Drive A error. System halt" And you said that you had no Floppy. On the first screen were you see your time etc there will be something that says halt on all errors. Change that to halt on keyboard errors only. The wording may be different but you get the gist right?You don't want the bios seeing no floppy and halting on that.I hope this helps you and don't get discouraged. There is usually a simple answer.
Dec 13, 2008 | ASUS A8N-E Motherboard
IBM ThinkPad T40 Hard Drive Problem
HI IM LOOKING FOR THE DRIVRS FOR MY LABTOP T40 I NEED ALL OF THEM I LOOKED IN TO IBM SUPPORT.COM BUT I CANT FIND IT SO IF ANYONE KNOW WHERER I MAY FIND IT HELP ME OUT THANK YOU
Sep 22, 2008 | IBM ThinkPad T40 2373 Notebook
Motherboard issues
Dear, friend
When connecting IDE devices in your computer, there are a few rules you need to know about.
First, Master and Slave devices are different for the 80-wire cables and the 40-wire cables.
Inside your computer, you generally have two (2) IDE hard drive controller connections. They look this this 99% of the time:
[ The smaller one on the very top is a floppy drive controller connection )
Jul 01, 2008 | Computers & Internet
Lacie mobile drive 120 gb
I'd power it on and gently put it against my ear to sense if it's even spinning. If it's spinning, powerdown the computer, disconnect the drive and try it in someone else's computer. Let me know what happens. If it is not spinning, could either be an electronic error within the enclosure or the drive has received a static shock. If it was me, I'd remove the drive from the enclosure and put it into a different enclosure for 2.5" drives. It's only a normal laptop drive inside. I'd be interested in what you find out. ZT3000 "Beta tester of "0"s and "1's"
Aug 15, 2007 | LaCie (301074) 80 GB Hard Drive
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
