Question about Ricoh Office Equipment & Supplies
RAM CLEAR WHAT DOES IT DO
How to clear bizhub 163v memory
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings ?< ? ,< ? Quick Settings ? < ? >
3. The SERVICE MODE menu screen will appear.
11.10.2 RAM TEST
A. Use
• Write or read data to/from RAM memory to make sure of normal operation.
• When test finishes and everything is okay, it will display "RAM CHIP IS OK" and automatically clear DRAM.
After DRAM clear finish, LCD will display "DRAM IS CLEAR!."
B. Procedure
• Pressing the Menu/Select key will start the check.
• After approx. 30 seconds, "RAM CHIP IS OK" will appear.
Does not work have a tech come out
May 16, 2016 | Konica Minolta bizhub Office Equipment &...
What do I do about a RAM chksum error G2 on our Verifone V510?
Probably the best way to correct this problem is to clear the RAM and download your app. again. In other words start over with a clean slate. After doing this you still have the same problem, you may need to open the machine and disengage the battery. This would clear the RAM, but you would then need to clear the tamper error message. Call Frank @ 775-338-6634
Oct 15, 2014 | VeriFone VX510
Says printing but nothing is coming out
If it says it is printing and no paper is being fed, and you are not getting any paper jam indicators, thats not good.
To get this reset you may have to do a RAM CLEAR. This will mean all documents in memory and all programming in the machine( date, time, quick dial numbers etc, etc) will all be lost, and will have to be re-entered.
If you want to try the RAM CLEAR do the following....
Press Program, *, 3.....display should say All RAM Clear ( enter/cancel).....to perform the Ram Clear press ENTER
To finish without doing the Ram clear press CANCEL.
Apr 27, 2010 | Muratec F320 Plain Paper LED Fax
Can not get it to start up after putting in all five new batteries. screen is full of wierdness but will turn on/off.
Where that ''weirdness'' is coming from, I cannot say, but you can press the CLEAR key to clear the screen. Reset the calculator Ram.
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Press [CLEAR] to erase the "Ram Cleared" message.
Make it a habit to exit thid-party programs/games after each use. They have a tendancy to get stuck in RAM, thus preventing you from using your calculator.
Hope it helps.
Thank you for rating the solution.
Dec 07, 2009 | Texas Instruments TI-83 Plus Calculator
The calculator will not work and won't let me type anything. The only thing on the screen is a cursor and it is not blinking.
What kind of cursor? Is it checkered? If it is the memory is full that is why you cannot type anything anymore.
  1. Delete games,
  2. clear all lists [2nd][MEM][4:ClrAllLists][ENTER.]
  3. Clear entries [2nd][MEM][3:Clear Entries][ENTER.]
  4. If that is not enough reset Ram [2nd][MEM][7:Reset][1:All Ram] [2:Reset][ENTER]. Clear the Ram Cleared message.
Hope it helps
Dec 04, 2009 | Texas Instruments TI-84 Plus Calculator
Gives error memory message when tries to change
See if the cursor is checkered. If so, the calculator is out of memory.
You may have very little memory available and then wanted to create a table with a very small DeltaTbl (the table step). If the step is small, and the domain is large, very many points will have to be generated and that may make the calculator unable to comply for lack of RAM.
I suggest you free some Ram by clearing the lists, clearing the entries. To do so you press [2nd][MEM][3:Clear Entries] to clear entries, then press [2nd][MEM][4:ClrAllLists] to clear the lists.
Alternatively, you can just reset the Ram by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then clear the Ram Cleared message and start again your table.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 01, 2009 | Texas Instruments TI-84 Plus Calculator
When i try to enter a non-linear function (y=x2-3x-2) the screen says:err:invalid dim /quit
Clear the contents of old variables you may have used. Reset RAM and start again. To reset RAM press [2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Then press [CLEAR] to clear the message.
Hope it helps.
Oct 01, 2009 | Texas Instruments TI-84 Plus Calculator
The Screen displays random lines and numbers.
Clear the screen. Reset RAM :[2nd][MEM][7:Reset][All ram] [2:Yes] Ram cleared is displayed. [Clear] the screen.
Hope it helps.
Sep 19, 2009 | Texas Instruments Office Equipment &...
Chassis intruded!!
Clear RTC RAM (CLRTC)
This jumper allows you to clear the Real Time Clock (RTC) RAM in CMOS. You can clear the CMOS memory of date, time, and system setup parameters by erasing the CMOS RTC RAM data. The onboard button cell battery powers the RAM data in CMOS, which include system setup information such as system passwords.
1. Turn OFF the computer and unplug the power cord.
2. Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
3. Plug the power cord and turn ON the computer.
4. Hold down the <Del> key during the boot process and enter BIOS setup to reenter data.
Except when clearing the RTC RAM, never remove the cap on CLRTC jumper default position. Removing the cap will cause system boot failure!If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After clearing the CMDS, reinstall the battery.
You do not need to clear the RTC when the system hangs due to overclocking. For system failure due to overclocking, use the CPU Parameter Recall (C.P.R) feature. Shut down and reboot the system so the BIOS can automatically reset parameter settings to default values
Mar 18, 2009 | ASUS P5V800-MX Motherboard
12 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
