Question about Stoves Premier 900DCa Dual Double Oven
Replace thermostat Please help
I have a smooth top kenmore oven model #92172300 when you use the oven it gets to the temperature but then its shuts the heat off i had heating element tested and its good please help
The thermostat controls the heating element. If it comes to temp you know the element is OK. The thermostat can be tested. or just replace it.
Nov 18, 2016 | Kenmore Ovens
Over heating fan oven
it sounds like you tod is faulty its the little stat at the back on the right hand side two wires going to it ok make sure to swicth oven off
Oct 14, 2012 | DeLonghi Ovens
Model : ACE 23300 S/N IMD 2676010 Type 24 Admiral ranger After someone turned around the timers, the oven part of the range stopped working. Cookotps still work. All the fuses are good, the lamp...
You will need to replace the oven temperature switch. I did not find any parts available for that unit to direct you to. Do you have anymore information on it?
Aug 03, 2011 | Ovens
Oven gets to hot
Hi j_hallinan,
The Thermostat is most likely defective.
I'd suggest taking the thermostat out, and showing it to your nearest Appliance Spares outlet. They should be able to give you the correct thermostat to replace it with.
Regards :-)
* If you found this solution helpful, please rate it.
Jul 08, 2011 | Ovens
Oven not working but grill is please help
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Dec 12, 2010 | Smeg SE250XUK Stainless Steel Electric...
I have bought a replacement main oven Thermostat for a tricity bendix Town & Country Mod no SIE459TCGR the conections on the replacement thermostat 46THC15/F5G1E2 are different from the original can...
Hi.
This is an universal replacement part, that is the reason why it is different from your TB original part.
The thermostat should have the temperature probe already attached.
Fit temperature probe and thermostat, then connect the element (s) wires on one side of the thermostat. The order in which you connect element polarity to thermostat does not matter. The thermostat will cut off power to element when the specific temperature is being reached by the temperature probe.
Dec 12, 2009 | Ovens
Electric fan oven overheating
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Mar 01, 2009 | Equipex PZ-330 Electric Single Oven
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Stoves Premier 900DCa Dual Double Oven Logo
21 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
