Question about Samsung Un40eh5000f
Image ghosting ghosting
Ghost image on a hp CM1415
Two reasons for ghost image
1. Toner cartridge faulty.
There is a part in toner cartridge called Drum cleaner (also called as tractor blade), if this part not clean the drum surface properly ghost image will form on drum & it will transfers on paper..
2. Fuser assm faulty.
There is a part in fuser assembly called Teflon sleeve. If toner particles deposited on teflon sleeve you may get ghost image..
May 08, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
Is it possible to create one generic win 7 ghost image and use it on any pc or laptop. I've tried this in the past with xp and it was an epic failure; sometimes it worked after ghosting, sometimes it...
A ghost image can be used on only one computer the same image cannot be replicated on other machines. Create a different image for the other computers and then burn the image file to the DVD drive for future use.
Dec 19, 2010 | Computers & Internet
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
Copies have ghost image
yes. although I would first check the fuser unit. It is located the exit side of the copier. let the copier cool down before handaling the teflon fuser roller. The upper roller has a teflon coating, if it is worn the image will not transfer properly to the paper thus leaving a duplicate / ghost image. Good luck
Nov 24, 2008 | Office Equipment & Supplies
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
Epson C1900 "ghost " images
Sounds like the transfer roller or the fuser unit may be faulty. Look at the fuser to see if the roller surfaces are dirty. If so, replace the fuser.
Jul 20, 2008 | Epson AcuLaser C1900 Printer
Why restore ghost image
You will need to restate your problem in better english.
Jan 07, 2008 | Symantec Client Migration 3.0 Add-On to...
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Samsung Un40eh5000f Logo
12 people viewed this question
Jerry Greenberg
Jerry Greenberg
