Question about Sylvania Audio Players & Recorders
How do you adjust alarm/radio volume?
Alarm blast you awake!
2 Suggested Answers
SOURCE: Wharfedale Micro cd/clock radio alarm volume!!!
Same problem with same device.
Posted on Apr 01, 2008
ZX clock radio: How dor i control the volume of the alarm ? How do i swtich from buzzer to radio for wake up?
I have owned several radio alarm clocks and I have found them all fairly intuitive to operate - no instructions needed, though sometimes it takes a short time of playing around to fill in the operating details.
The alarm buzzer is generated by the audio part of the radio and so those clock radios that do have a buzzer with adjustable volume it is controlled by the radio volume control. In this case it is usually the case that falling asleep to the radio with the volume turned down results in not being woken next morning because the alarm isn't loud enough.
Switching from radio alarm to buzzer is usually intuitive but in the absence of instructions there will be a limited number of switch combinations to play around with.
Nov 07, 2017 | The Audio Players & Recorders
How can i change the alarm volumn on the radio on onn ONB14AV201
ONB14AV201 alarm clock with gradual wake alarm function. Radio alarm sound level will start from 0-15 within 12 to 15 second when alarm on. You can adjust the radio alarm volume by press the "ALM2/VOL?" or "ALM2/VOL+" buttons.
Feb 25, 2015 | Audio Players & Recorders
I have model ONA13AV501. And I cannot adjust the volume on the alarm..I can not find the directions in the guide - pg 10. please instruct
The alarm volume is rarely adjustable but if it has the option of using the radio for wake-up instead, you can set this as you wish.
Feb 03, 2015 | Audio Players & Recorders
2011 gmc terrain, security alarm goes off after doors are locked with key fob, it is erratic no set time when alarm goes off, keeping neighbors awake
Locate the sensors,one is faulty.Induction sensors just about everywhere(I think they are illegal)but most likely in the doors ,shock is preaty close to the alarm cdi,smal case with a dancing spring inside may be needed an adjustment in sensibility,it has a knob on the case,air volume sensors just over the head,in front,look like litle speakers (tiny)or microfons,unplug one at a time.Bst guess:adjust shock sensibility..
Oct 22, 2013 | 2011 GMC Terrain
Cracking & popping radio
The volume control pod needs to be flushed with electronic control cleaner, unplug and remove back, attach supplied straw and give the pod two or three good blasts in the tiny hole and rotate volume back and forth rapidly to reach desired results.
May 20, 2012 | Vintage 1930's Replica Cathedral Radio and...
I have the xdvd710 when i start my truck up volumn is blastin every time!!!!! how do i get it to stop?????
The dual XDDVD710 RADIO has a volume memmory (it seems), it will go to the last volume setting that it was set to, not play to,(supposly to keep it from blasting you when you turn it on and you forgat u had the volume on blast).
To set it,
1 turn radio on,
2 turn the volume to desire Level you whant it to go when you turn it on (other Levels besside BLAST hopefully) ,
3 push the volume button in, that should do it.
Now you can play your music loud and should you forget that you had it on BLAST (to over come road noise) when you last played your radio, it should start at the preset volume.
Dec 09, 2010 | Dual XDVD8170 Car DVD Player
My Sakar Darth Vader helmet clock radio did not come with instructions. How do you get it to talk and not just play the radio?
When you set the alarm, turn the volume button on the front counter-clockwise (volume down) until it clicks. Darth will then wake you with one of three extremely LOUD, over-modulated soundbites or the electronic "beep-beep-beep" alarm . You can select the different soundbites/alarm with the "SELE-AL" button on the back. The only problem is, you can't tell which one you've selected until the alarm goes off. Cheap design.
Oct 07, 2010 | Sakar Darth Vader Helmet Clock Radio
Alarm clock
The clock radio is mediocre, according to at least 15% of owners. First, the radio reception lacks clarity and the sound is tinny. Second, there are many small buttons and it's impossible to tell which is which in a dark room. Third, because the volume and radio tuner are adjusted by moving a dial, it is easy to accidentally move the device and turn down the volume as a result. This can be a problem if you've set the clock-radio alarm and the radio volume is too low.Kindly check these first.
Jan 27, 2010 | Homedics Sound Spa Classic Clock Radio
ALARM CLOCK SETTING
I've manage to set it... press time/awake and the 1 flashes... use arrows to set the time... then press time/awake again for alarm 2.
But how do you know when it is actually set?? it did not go off this morning and i was late for work!
Mar 14, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
127 people viewed this question
Top Sylvania Audio Players & Recorders Experts
David Payne
David Payne
R Buschy
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
