Question about Samsung HL-S5087W DLP TV
When turning on the TV, I hear a banging/grinding sound.
I have a HLS5087W that is 3.5 yrs old. My problem first started with the TV shutting off by itself. I would turn it back on and watch for a while, then it would shut off again. Often this occured for approx 20 minutes, then it would just stay on without shutting down. Now when I first turn on the TV, I hear a banging/grinding sound, but after 10 seconds, the TV is fine (good picture, no banging/grinding). Most days, the TV will run fine for hours, but then it shuts itself off. When turning it back on, the banging/grinding noise starts but doesn't stop. It even continues about 30 seconds after the power is off. The TV then will have to be off for several hours, before it can be turned on without the banging/grinding continuing. I have replaced the bulb, but feel maybe the ballast or fan may be the problem. What sould I try next?
    Scholar:
  • 39 Answers
If you hear a grinding,whirling,spining or buzzing sound, that sounds to me like the COLOR WHEEL,the reason for that is because your color wheel spins at 5,000 rpms(revolution per minute) and something that modifies the balance of the disc can cause different things,Unfortionatelly the only way to check that the color wheel is working properlyis you need to check it out physically
I did some research and I found the color wheel at DM;http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?CLICK=52978
Please keep us posted.
Posted on Oct 01, 2009
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Ours is 2 yrs old.TV turns off by itself every 2-3 min.
U replaced the projection lamp the last 2 years?U used the tv on and watches 4 or 5 hours a day?Yes,the tv projection lamp life is over.Require changing a new projection lamp.
Aug 03, 2010 | Hitachi UltraVision 60VF820 TV
Tv plays for about 10 min then 3 lights on front start blinking turns tv off
Hi,Is your tv between 6000-8000 hrs or 2-4 yrs, and are getting the 3 led lights.If so it might be time to replace the lamp.Your part # will be BP9601472A and you can find it here: http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hls5087w-lamp-sm.htm and here's the instructions to replace it: http://www.fixyourdlp.com/guides/samsung/BP96-01472A.php Have a blessed one!
Mar 22, 2010 | Samsung HL-S6186W 61" HDTV
Darkerning picture
Please replace Lamp in TV and lamp replacement procedure is written in instruction manual if you want to do it yourself.
Feb 04, 2009 | Samsung HL-S5087W DLP TV
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
What a mistake!
Find a cliff and push. It will save you alot of money and headaches
Aug 30, 2008 | Toshiba 52HM95 52" HDTV Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
RCA TruFlat TV
You may have a loose solder connection on the circuit board inside your set.
You need to have a technician check it for you.
Stargazer
Jan 16, 2008 | RCA 27F530T 27" TV
Samsung DLP HL-P4663W
could be the lamp, and is about time for a new one
http://fixyourdlp.com/blog/?cat=4
Jan 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5087W DLP TV Logo
364 people viewed this question
Jerry Greenberg
Jerry Greenberg
