Question about Briggs & Stratton Garden
Torque specs 28r707
28r707 1140e1 rebuild torque specs
johnny5846
  • 379 Answers
SOURCE: Looking for the torque specs for 1998 chevy astro van?
1998 chevy astro 4.3 v6 torque specs include :
* foot pounds *
balance shaft (if equiped) gear bolt = step 1 = 15 ft.lbs. step2 = additional 35 degrees.
camshaft sprocket bolt = 18 ft. lbs.
connecting rod cap = step 1 = 20 ft. lbs. step 2 = additional 70 degrees.
crankshaft damper bolt = 74 ft. lbs.
crankshaft oil deflectorbolt/nut = 27 ft.lbs.
cylinder head bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees. (tighten in sequence)
exhaust manifold bolts = step 1 = 11 ft. lbs. step 2 = 22 ft. lbs.
flywheel bolt = 74 ft. lbs.
main bearing cap bolts = step 1 = 15 ft. lbs. step 2 = additional 73 degrees.
oil filter adapter bolt = 15 ft. lbs.
oil pan bolt/nut = 18 ft. lbs.
oil pump bolt = 66 ft. lbs.
rocker arm with press in studs = 18 ft. lbs.
rocker arm with screw in studs = 19 ft. lbs.
valve lifter retainer bolt = 12 ft. lbs.
water pump bolt = 33 ft. lbs.
* inch pounds *
balance shaft retaining plate bolt = 106 in. lbs.
camshaft retainer plate bolt = 106 in. lbs.
front cover bolt = 106 in. lbs.
intake manifold upper = step 1 = 44 in. lbs. step 2 = 88 in. lbs.
intake manifold lower = step 1 = 27 in. lbs. step 2 = 106 in. lbs. step 3 = 133 in. lbs. ** (tighten bolts in sequence)
thanks for your vote !
Posted on Dec 28, 2008
chuck943
  • 783 Answers
SOURCE: torque specs 7.5 inch rear axle 96 ford ranger
Differential bearing caps 70-85 ft lb
Ring gear bolts 70-85 ft lb
Pinion bearing preload if using original bearings 8-14 lb-in, if installing new bearings 16-28 lb-in
Posted on Jan 30, 2009
  • 3567 Answers
SOURCE: need torque specs for 98 yz 250,rebuilding engine
Go to the site below and you can download a free srevice manual for your bike.
http://www.carlsalter.com/motorcycle-manuals.asp
Top rating due on this answer!
Posted on Apr 13, 2009
SOURCE: need torque specs for a 85 s10 chevy with a 2.5 engine?
here you go!
Posted on Jun 21, 2009
  • 108 Answers
SOURCE: engine torques
the best solution is to google a bolt torque chart then crosrefrance your bolt size with torque value i have a chart on my wall.
Posted on Mar 13, 2010
What are engine rebuild specs and torques?
REALLY perhaps the manufacturer knows .
Apr 13, 2016 | Cars & Trucks
What are torque specs on 1965 ford 7 and 1/4 inch rear
I have a '68 Motor's manual (goes back to'58) the only rear end specs I can find are for the pinion nut (140 ft. lbs.)
pinion preload: 17-27 in. lbs. w/integral carrier or 22-32 in.lbs. w/ removable carrier. Tightening the carrier bearings isn't so much a torque setting but more or a tightening procedure. Theses specs are done during the rebuild so I wonder if you're asking about the bearing caps or bolts that hold the diff. to the axle housing? I could not find a spec. for bolt torque. Since the bolts that hold it in (if that is what you asking about) are not a bearing adjustment, you can go with a generic torque based on bolt size. Again, I'm not sure what component, or bolts it is you are asking for torque specs on.
Sep 17, 2014 | Cars & Trucks
What are engine torque specs
witch engine go to autozone or similar parts house and ask for them to print the torque spects for that engine
Aug 22, 2014 | Cars & Trucks
TOYOTA HILUX 2006 engine head torque specs
it depends on the size of the screws. i recommend to set torque as 100lbs for new bolts, 90 for old bolts
Feb 29, 2012 | 2006 Toyota Hilux 3.0
Wanting to know rb20det engine torque setting
  • Head torque settings
    These are the specs I used on my own last rebuild
    Head is torqued down in 5 stages
    1. 22ftlbs
    2. 72ftlbs
    3. slacken off
    4. 22ftlbs
    5. 75ftlbs or 90o
  • Engine torque setting
    Main bearing torque 40ft/lbs
    Big end bearings..... also 40ft/lbs
  • Oct 12, 2010 | Crystal Decisions NISSAN SKYLINE GTR R32
    Torque specs 7.5 inch rear axle 96 ford ranger
    Jan 30, 2009 | 1996 Ford Ranger SuperCab
    Garden Logo
    81 people viewed this question
    Top Briggs & Stratton Garden Experts
    Phil Walker
    Phil Walker
    John Trevino
    donald boissonneault
    Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
