Question about Instant Mosaic Metal Tile: 12 in. x 12 in. Peel and Stick Faux White Marble and Brushed Stainless Metal Wall Tile EKB-03-108
How do you cut the brushed steel
Do you cut it with a wet saw?
Troubleshooting chicago 7" tile saw
problem power switch
brushes worn
problem armature
circuit breaker for power point
Jul 11, 2016 | chicago electric power tools 7" Portable...
Bogs down while cutting does carb need adj.
Every saw is going to bog down some when cutting. What condition is the blade? I would need more information on what kind of saw it is in order to try and help. Is this gas powered? Wet saw? Wood, concert or steel?
May 15, 2014 | Saws
My MK-100 does nothing when I turn on the switch.
Check the brushes for the motor. very common problem in electric motors. It should look like a slotted head of a screw on the side by the motor. Only its plastic and about the size of a dime. After removing the brush, or magnet is what it actually is, replace it. Very cheap to replace and most hardware stores carry them. Hope that helps. Otherwise the switch is bad
Jun 27, 2012 | Mk Diamond MK - 170 Wet Cutting Tile Saw
My MK370 tile saw has a burning smell and it is making a slight banging noise every 7-9 seconds. The saw is cutting tile fine otherwise.
The problem could be bad brushes. Otherwise, you are probably burning the windings inside your motor. The slight banding noise could be an issue with the bearings in the motor itself. In which case you will soon be replacing the motor, so... we'll hope the brushes prove bad.
Assuming the motor has brushes, there will be 2 semi-large buttons on the motor (one on each side). They are screws. Remove them and beneath each one is a "brush". They should be long, hard, crack free, and smooth on the bottom where they touch the rotor. If not, then replace them. Almost all motors used for tools have brushes and some motors require disassembly of the motor itself to replace the brushes, but in your case, it should be an easy job. I can see one of the buttons on the Amazon picture.
:o)
Jun 03, 2011 | Mk Diamond 159943 MK370K 114Horsepower...
Will this saw be able to cut steel on truck and trailer frames? the steel may be 2-3 inches thick in some places. other places only about a half inch thick. is this a good tool for cutting heavy metal?
Never heard of cutting steel with a chain saw. What works best for me has been a sawzall with a good quality steel cutting blade. The real thin metal cutting blade on a circular saw works pretty good also.
Mar 28, 2011 | Husqvarna Garden
Shorting out
have you checked the brushes ???
Aug 06, 2009 | Wet International Mk Diamond 153330 Mk 660...
Jig Saws Blades Types
High Speed Steel - Used for wood and light metal cutting Bi-Metal - Also used for wood and light metal cutting. Cobalt Steel - Tougher and lasts longer than Speed steel and Bi-Metal. Used for wood and metal. Carbide Grit - Strictly used to cut masonry board. Scrolling - Thinner than the regular jig saw blades and are used for tight turning cuts.
Aug 27, 2008 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Instant Mosaic Metal Tile: 12 in. x 12 in. Peel and Stick Faux White Marble and Brushed Stainless Metal Wall Tile EKB-03-108 Logo
Top Instant Mosaic Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you an Instant Mosaic Building Material Expert? Answer questions, earn points and help others
