Question about Toshiba 58" Black LED 1080p HDTV - 58L1350U
58 in toshiba didn't turn on for 10 days, turned it on a gray white screen keeps flashing
My 58 in is not functioning, keeps flashing a white gray screen
3 Suggested Answers
SOURCE: menu gray area turns black can not exit from menu
my remote will not exit from menu
Posted on Dec 09, 2008
leecom72
  • 4806 Answers
SOURCE: Screen turns white
Hi there.
The ribbon cable which runs behind the screen has either become loose or has become defective.
If you still have warranty on the laptop send it in for repair, if you don't post back and i will tell you how to disassemble the screen to get to the ribbon cable.
If the ribbon cable is faulty you can of course use an external monitor so you can still use the laptop.
Good luck and thanks for using FixYa!!
Posted on May 26, 2009
How to use the program for the machine
hi dear just turn off the main power and hold 0and5 key togather and turn on the power holde the 0and5 for about 5 to 10 sec u will see the 00 digit flashing on the screen thats mean u are in program mod.
thanks
May 17, 2010 | Toshiba 1370 Black and White Copier
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
Nov 22, 2009 | Panasonic CT-27SL14 27" TV
Completely white/gray screen
First try this: shut it down, disconnect the power cord, pull out the battery, then hold the power button for a full 10 seconds. Reinstall the battery, reattach the power cord, turn it back on.
Still doing it? Put the reboot disk that your Mac came with, or the disk to the version of Mac OS X that you're running.
To start from disk hold "C" as your Mac is first turning on from a complete shutdown.
Dan Crowley, iKnowApple.com 919.280.3101
Nov 08, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
White Screen on Toshiba Gigabeat F40
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 31, 2008 | Audio Players & Recorders
Gray Screen
I had a very similar problem where my Sansa would turn on show the initial logo then fade to a white/grey screen and restart. To fix it started in recovery mode (Start in hold mode with rec button held down) then used the firmware updater to update the software and it seems to had fixed the problem hope this also works for you
Jun 01, 2007 | SanDisk Sansa e250 MP3 Player
Toshiba 58" Black LED 1080p HDTV - 58L1350U Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
