Question about Garmin nuvi 1300 Car GPS Receiver
Shuts off during navigation
Takes a long time to load then when you finally start route it shuts off then turns on then shuts off
  • Garmin Master
  • 2,130 Answers
This is often caused by no memory left on the unit, corrupted map or system files and a large trip log. Please see this link for more info on boot-up issues:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Posted on Mar 23, 2014
Why is the navigation not re-calculate route
Your still under factory warranty so take it back to the dealership.
Aug 04, 2014 | 2014 Toyota Highlander
The GPS system on my Boss BV9370NV loses navigation from memory during a trip when the engine is shut off and restarted . The clock and programming for the radio and presets are ok, only the GPS system ...
If you are getting power from the cigarette lighter socket for the GPS unit you loose power when you switch the engine off. If that is the case find a power line that has power all the time and hook into it to give permanent power to the GPS
Mar 17, 2013 | Bv9370nv Double-din In-dash Navigation A/v...
Many times my navigation system leads me to roads that are unnecessary to follow (like a tourist-view route), it only costs me more time if I follow exactly the same ways he asks me to follow. I wish it...
Go to Tools.... Settings....Navigation.....under Route Preference set it to Faster Time if you need to change it just press to Shorter Distance or Off Road.... if you change it make sure you press OK n bottom screen
Faster Time I use
Next
Avoidances.....should be Enabled......press it....make sure Highway is Not checked... if you make changes here also press Ok on bottom screen
I only keep checked U-turns ...Traffic...Car Pool ...Unpaved roads
Before you travel, add your route to the GPS, do a trial run from home and see which direction it is taking you by pressing the turn arrows
If that isnt the way you want to go, on the map screen press menu then press detour, this will take you in another direction again scroll down the turns and see the route
Oct 30, 2010 | Garmin Nuvi 350 Car GPS Receiver
I got the VR3 gps with back-up camera less than a month ago, the first day it worked perfectly fine, then when I installed the route 66 stuff it started showing me some really long message saying to...
Ok so this happened to my gps after an improper shut down. Here is how I fixed it. Follow each step carefully and make sure your gps is fully charged before beginning.
1st open up the route 66 disk to see files not actually accessing the program. Right click on the disk and tell it to open from my computer. you will see many files one folder will say memoryimage.
2 Then on the gps click on settings and go to backlight setting backlight to the dimmest stetting. Now go into power and tell your gps to never standby.
3 Plug your gps into your computer then turn it on. Windows mobile will come up click on connect without setting up your device. Under file management click on browse contents of your device. You will now see what is actually on your gps. Open NANDFlash.
4 Now select all items except the route66 folder in the memoryimage folder of the disk and move them into the NANDFlash folder of your gps. When it asks how to transfer tell it to replace current folders with the same name. It will then take several hours to transfer.
5 On mine the route 66 exe file would not transfer back into the actual route 66 folder so I created a new folder then transferred the route 66 exe file from the route 66 folder in memoryimage of the disk into my new folder in NANDFlash. Once it is transferred you should be able to click navigation on the gps and have your gps load route 66. Your maps will be locked.
6. I kind of forgot how I did the next step because I cannot get back to where I was because I have already activated my gps. Go into the main menu from inside route 66 and either enter the extras folder or route 66 settings. Somewhere in one of these you will find a place to activate your route 66. It will then give you a website and an id for your gps. Go to the website and enter your gps id and the code from the voucher code card which came with your gps. Once entered on the website you will receive an activation code which you will have to enter into your gps. I recommend you turn off your gps then turn it back on and give it time to find you. You can go into gps status to watch for a signal and once you have a good signal it may take several minutes to locate you. After it has found you it should be working fine.
Aug 06, 2010 | GPS
Can i program a route that i normally take instead of the route the gps gives me
After you program your destination using 'Navigate to...', you can specify your specific instructions by using 'Find alternative' -> 'Travel via' and/or 'Avoid part of the route' until the generated route largely satisfy your requirements. then finally, 'Calculate alternative'
Hope it helps: let me know how you go.
Jan 07, 2010 | Tomtom ONE GPS Receiver
My nuvi 760 routes me the long way around
You should do the following: Changing the Navigation Settings;
Touch Tools>settings>Navigation. There you'll find how the sysytem will calculate your route.Route Preference.........Faster Time....Shorter Distance.......Off Road....Avoidances,very helpfull....Restore original navigation settings.
Hope this will help you,
JADF
Mar 24, 2009 | Garmin Nuvi 760 Car GPS Receiver
Boot up takes too long
This happens when the computer gets full of "junk" (this happens with any computer over time) and can be remedied with a fresh windows install.
If you don't plan to reinstall windows in near future I suggest you go to Control Panel -> Add/Remove Programs and uninstall any software you don't use/need
Also tweaking the system registry migh help speed up boot time:
1. Click ‘Start’ then 'Run’
2. Type in ‘Regedit’ then click ‘Ok’
3. Navigate to ‘HKEY_LOCAL_MACHINE\SYSTEM\Cur rentControlSet\Control\Session Manager\Memory Management\PrefetchParameters\ ‘
4. Right-click on “EnablePrefetcher” and set the value to ‘0′
5. Close 'Regedit'
6. Navigate to 'Windows\Prefetch' folder (usualy drive on C:) and delete all its contents
5. Reboot.
7. Enjoy greatly improved boot time ;]
Hope this helps!
Oct 01, 2008 | Shuttle MS51N Motherboard
Finalizing dvd
I had the same problem for about an hour. I finally got it, though not sure how. I think it had something to do with the green button on the on/off switch. I pressed it down while at the same time pushing the on/off button down to "mode". When I went back to finalize it yet again, I got the option to select "Yes". Hooray!
Dec 24, 2007 | Panasonic VDR-D100 DVD Camcorder
Garmin nuvi 1300 Car GPS Receiver Logo
78 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
