Question about 10/40/200 Amp 6/12-Volt Manual Battery Charger - SE-4020
My 6-12 volt switch dont do anything when flipped to boost
I have a model 914 H battery charger 10/40/200
    Master:
  • 710 Answers
It is broken.
Posted on Sep 01, 2014
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Tip
Emergency 12 volt tester.
Ever have the need to test something on a car or truck, just to see if it's good or bad? If you've got a 12 volt battery charger, you've got a ready made tester. Take two metal paperclips and straighten them out. Clamp them in the alligator clips of the battery charger and use them as probes to test things to see if they work or not. You can use this on anything that runs on 12 volts dc. You can test electric motors, actuators, starters, light bulbs, sensors, switches, etc. With a long extension cord you can reach every part of a venicle. If you have a portable, rechargeable batttery charger/booster, then you have a mobile tester.
on Jan 12, 2011 | Chevrolet Silverado 1500 Cars & Trucks
How long does it take to charge a 12 volt battery from a boost
Depending upon the size of your battery and the outdoor temperature, it may take a couple of hours for a full charge from nothing.
May 19, 2014 | Black & Decker Black And Decker 12 Volt...
Peg perego 12 v tractor does nothing switch clicks
first of all check the battery and charger and make sure that they are both putting out 12 volts
Dec 27, 2012 | Peg Perego John Deere Turf Tractor
How do you charge the 12 volt battery with a 6 volt charger
  • A 6 Volt charger will charge a 12 Volt battery, it will just take twice the time to get the 12 Volt battery to full charge as a 12 Volt charger would take. V*I=W. It will take up to 36 hours to get a full charge from near dead but it will work just fine.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 27, 2011 | Electric Kid Trax C6 Corvette Ride On
It runs the battery down
Does your frig have 110, Gas and 12 volt setting? ... or is it auto select?
This is the way they should work ... if there is 110 Volts, it should run on 110 volts. The device is still controlled by 12 volts but the heat source is electric. If there is no 110 volts, it should switch to gas as a heat source. Same deal with the control, runs on 12 volts. If there is no electric and no gas, it should select 12 volts for a heat source ... same deal with the control. Problem with 12 volt source for heat is it GOBBLES up the power in your battery.
How is your battery? Do a volt test on the battery and the charger. Charger should run about 14 volts. Battery should provide at least 11 volts. If it is such that you can measure the acid, a good reading is 1200. Your charger can provide only about 15 amps charging power. Your battery should be able to provide up to 110 amp/hours.
If you do have electric and gas, it may not be your frig that is killing the battery ...
Thanks for your quesiton @ FixYa.com
Mar 21, 2011 | Dometic RM2852 Refrigerator
HI, I was asked by someone if the Kymco S 200 has an alternator? Does it have one? Is there anything that can charge the battery, when not in use? Thank you Sincerely, John
Yes you can charge the battery with a battery tender, or battery charger, when the bike is sitting.
Your People S 200 requires a 12 v, 6Ah battery.
Fully charged will have 13.1 Volts
Undercharged 12.3 Volts
Most battery tenders use low amps to charge and wont overcharge your battery.It just maintains it at 12.5 Volts.
If you use a battery charger, be sure you monitor it regulary, as some models don't shut off.
Dec 13, 2010 | 2005 Kymco People S 200
I have a mikita 12 volt and when I charge it it wont hold charge.
do you have a volt meter toi check the charger voltage? if so then read the voltage out of the charger, it should be 1 or 2 volts higher than the listing 12v would be 13 or 14 volts. if it's working you probally do have a bad battery. if the charger is out then you have a bad charger.
Aug 03, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Battery charger on 2008 Chevrolet Equinox
most chargers have a few different settings you want to put it ona slow charge for about 4-6 hrs bye slow charge I mean it should have a 2amp or a3amp trickle charge unless you are attempting to start the car immeditly the you will you the setting labled starting
Mar 01, 2009 | 2008 Chevrolet Equinox
10/40/200 Amp 6/12-Volt Manual Battery Charger - SE-4020 Logo
101 people viewed this question
Top Schumacher Vehicle Parts & Accessories Experts
Ruben Diaz
treeeee
treeeee
Rigger
Are you a Schumacher Vehicle Part and Accessory Expert? Answer questions, earn points and help others
