Question about Vodavi 30-Button XTS Telephone
DISPLAY ERROR Our display converted to Chinese and then we unplugged it to reset - now the current display on has a solid blocks along the top and will not display any information for calls.
How to change weather from Chinese cites to cities in Australia?
First of all, you need to select the phone language to English or whatever you want. Your all gadgets will follow the same language. Somply click on weather gadgets and select the right top Setting Icon. Select your city along country and that's it.
Enjoy !
Sep 28, 2015 | Cell Phones
How can i convert chinese or japanese to english on car navigator?
try powering the unit on while holding the bottom right of the screen. this should allow you to choose what language as part of a master reset.
Jul 09, 2014 | Garmin nuvi GPS
Www canontechsupport com
Usually an error 5100 code is saying that the ink carriage has problems. Usually something currently is or recently hammed the cartridge carriage. With the machine turned off and the power cord unplugged, open the machine and inspect the inside do you see any stray pieces of paper along the paper's usually route?
There is a way to reset the machine to clear out the error. I would need to know the exact model of your Canon.
for more help visit CBR Tech Solutions
Apr 02, 2014 | Canon Office Equipment & Supplies
How to reset a samsung pl201?
.adslot-overlay {position: absolute; font-family: arial, sans-serif; background-color: rgba(0,0,0,0.65); border: 2px solid rgba(0,0,0,0.65); color: white !important; margin: 0; z-index: 2147483647; text-decoration: none; box-sizing: border-box; text-align: left;}.adslot-overlay-iframed {top: 0; left: 0; right: 0; bottom: 0;}.slotname {position: absolute; top: 0; left: 0; right: 0; font-size: 13px; font-weight: bold; padding: 3px 0 3px 6px; vertical-align: middle; background-color: rgba(0,0,0,0.45); text-overflow: ellipsis; white-space: nowrap; overflow: hidden;}.slotname span {text-align: left; text-decoration: none; text-transform: capitalize;}.revenue {position: absolute; bottom: 0; left: 0; right: 0; font-size: 11px; padding: 3px 0 3px 6px; vertial-align: middle; text-align: left; background-color: rgba(0,0,0,0.45); font-weight: bold; text-overflow: ellipsis; overflow: hidden; white-space: nowrap;}.revenue .name {color: #ccc;}.revenue .horizontal .metric {display: inline-block; padding-right: 1.5em;}.revenue .horizontal .name {padding-right: 0.5em;}.revenue .vertical .metric {display: block; line-height: 1.5em; margin-bottom: 0.5em;}.revenue .vertical .name, .revenue .vertical .value {display: block;}.revenue .square .metric, .revenue .button .metric {display: table-row;}.revenue .square .metric {line-height: 1.5em;}.revenue .square .name, .revenue .square .value, .revenue .button .value {display: table-cell;}.revenue .square .name {padding-right: 1.5em;}.revenue .button .name {display: block; margin-right: 0.5em; width: 1em; overflow: hidden; text-overflow: clip;}.revenue .button .name:first-letter {margin-right: 1.5em;}a.adslot-overlay:hover {border: 2px solid rgba(58,106,173,0.9);}a.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}a.adslot-overlay:hover .revenue {border-top: 1px solid rgba(81,132,210,0.9); background-color: rgba(58,106,173,0.9);}div.adslot-overlay:hover {cursor: not-allowed; border: 2px solid rgba(64,64,64,0.9);}div.adslot-overlay:hover .slotname {border-bottom: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}div.adslot-overlay:hover .revenue {border-top: 1px solid rgba(128,128,128,0.9); background-color: rgba(64,64,64,0.9);}6_4_2012_11_48_48_am.jpgTurn The inner bit towards you until it goes in fully then turn it on and it might work. Thats what I did and it worked
Feb 12, 2012 | Office Equipment & Supplies
On model f1de108c, what does error code E7 mean? Yes I'm a newbe.
If you have this KVM device hooked up to a master surge or surge protector:
  • Power it down
  • Unplug the all kvm cables
  • Unplug power cable
  • Check the DIP switches and make sure they are all set to OFF position
  • Re-connect the power cable only
  • Press and hold the + and - buttons together for 30 seconds
The Bank Display should read, "15".
If it does not, then check to see if you are using converters or adapters on the KVM and/or Server End.
If you are, you'll need to remove them.
Next
  • Unplug the power cable
  • Set all the DIP switches to ON
  • Press and hold the + and - buttons for 30 seconds again.
  • Bank Display should be set to "00".
  • Connect your VGA, Kybrd, and mouse cable
You should now check and see the OSD coming up on the screen.
To get into the On-Screen Display (OSD) menu, press SCROLL LOCK, SCROLL LOCK,
SPACEBAR on your keyboard.
You should be able to see your master or server computer on the list.
Well the adapters are the main cause, its not that they do not work, but most of the times it causes the KVM to malfunction, hence not recommended. Apart from that if the KVM is connected to a surge master it causes the error.
But not to worry, now that we have reset the KVM it should not be a problem.
The + and - buttons actually releases the static current from the KVM.
Have a great day!
Jun 02, 2011 | Belkin OmniView PRO2 8-port KVM Switch
Running Windows XP Problem with HP Director Every time I try to open it an error message pops up that says... One or more ActiveX controls could not be displayed because either: 1) Your...
Upgrade from director to solution center.
With the limited information you have given, that's the best advice I can give off the top of my head. Director is old, solution center is current.
Mar 17, 2011 | Computers & Internet
I have a chinese n8 and i dont have the phone password.How to i go about it
my chinese n8 is working on test rejime(mode),what is blocking incoming calls ,how can I deactivate the current profile in orger to receive incoming calls?? what shall I do?
Feb 13, 2011 | Cell Phones
Converting between Forms When working with phasors it is often necessary to convert between rectangular and polar form. To convert from rectangular form to polar form: M = sqrt{A^2 + B^2} f =...
You can switch the display mode for complex numbers by pressing SHIFT MODE down 3 and picking one. This will display the current result in the selected mode.
You can also override the current display mode and specify the format. Add these keystrokes at the end of a calculation: SHIFT 2 then 3 for polar or 4 for rectangular.
Nov 24, 2010 | Casio FX-115ES Scientific Calculator
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
PD 170 Recording problem
defective image sensor block shud be the problem
Jun 13, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Vodavi 30-Button XTS Telephone Logo
24 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Matthew MacWilliams
ray gallant
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
