Question about Defiant Timers: 5-Amp In-Wall Digital Timer with No Neutral Wire 49815
Gro1 digital timer won't
Timer doesn't power
The humidity sensor reads "LL" ... What does that mean for a gro1 digital weather station ?
Humidity value is lower then the forecaster registers , they normally go no lower then 20% . If you are getting an LL that could mean where you are located the humidity was lower then 20%
Feb 18, 2015 | Measuring Tools & Sensors
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Manual test does not work Looks like it does but water does not come on
If the manual test doesn't work, I think the auto function won't work either. If that is true, your timer is running on the battery and there is no power. Remove the battery and see if it appears to be working. If not, check your outlet to ensure that there is 120 volts ac. Plug a light or shaver into the outlet. If the outlet is good and the clock has no power when the transformer is plugged, you probably need a new transformer.
Gary
Sep 26, 2011 | Orbit 57882 9 Station Super Dial...
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
Defiant Timers: 5-Amp In-Wall Digital Timer with No Neutral Wire 49815 Logo
77 people viewed this question
Top Defiant Home Experts
Donni Steen
Tom Chichester
Are you a Defiant Home Expert? Answer questions, earn points and help others
