Question about Honda GCV160 5.5HP 2300PSI GAS-POWERED POWER WASHER
Small clear hose on Honda power washer
Where does other end of small clear hose go?
    Sergeant:
  • 415 Answers
Sounds like the hose that goes into the detergent bottle.
Posted on Apr 21, 2014
4 Suggested Answers
  • 97 Answers
SOURCE: Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Posted on Mar 19, 2009
  • 3600 Answers
SOURCE: honda gx270 pressure washer. water is not coming out strong.
did you check the inline screen for dirt?
Posted on May 24, 2009
  • 623 Answers
SOURCE: Water is not coming out of my honda pressure washer
Any chance it froze during the winter? They do need to be winterized.
Posted on May 05, 2010
Honda lifter
I assume you are talking about the chemical intake tube... Most commonly you would see one end of the tube attached to the small tapered nozzle on the pump, and the other end which should have a small filter attached to it - is what you would submerge in a container of soap/degreaser/chemical solution of your choice.
If you have it set up in this way you will get the addition of whatever soap product you have the clear tube sitting in mixed into your spray stream. -- it's important to note that you will only get suction and soap flowing through if you are using the widest (black) spray tip. With the broad spray tip on you can get soap flowing either with or without the engine running - which can sometimes be helpful if you have to be careful of what you get the soap on.
Mar 21, 2014 | Honda Garden
Washer will just fill to the lower level for a small load when i put on large load it still fills to lower level and starts to wash as usual. Only probolem is the water level every thing else works fine
water level is controlled by a pressure switch that is connected to the lower part of the tub-it may be clogged-pull off the small rubber hose that is connected to the water level control knob-make sure the fitting on the tub is clear and the hose is clear-take the hose off both ends and blow through the end that connects to the control-cheers Denny
Oct 26, 2013 | Washing Machines
How do you fix low pressure on windshield washer fluid sprayer.
Its just plugged up, probably right at the nozzle it's a pretty tiny hole. To clear it out you need to find a small diameter wire that will fit inside the hole to clear the blockage. Something like a small gauge sewing needle or a straight pin. It can also get plugged up in the rubber tubing. Usually you can just blow through it with lung power. Just pull the tube off at the nozzle and run the washer this will tell you if it's the nozzle or the tubing.
Jan 22, 2011 | 1994 Honda Accord
How do you clean a washer hose
If you mean the water supply hoses, usually the intake screen becomes plugged with debris from the house water supply. The screen is removable with a small screwdriver or other small tool. Sometimes it helps to just reverse the ends of the hose and place the washer end into a sink or bucket. There should be a screen on each washer entrance connection that can get plugged as well. Hope this helps!
Oct 14, 2010 | Washing Machines
I have a unionpower up 150 premium pressure washer theirs a small hose that comes out at the back of the engine with a small filter at the end of the hose pipe I dont no what its for
If the hose actually comes out of the pump (look carefully) it sounds like the chemical pick up line. It would most likely be clear plastic tubing with a plastic filter at the end. You drop this into your chemical (soap, etc) container and under low pressure it will siphon the chemical and apply it through the wand.
Jul 29, 2010 | Garden
Washer will fill but it does not stop
Your water level switch is stuck.
Probably due to soap scum in the air dome line.
Remove the control console screws to access the water level switch.
Remove the small plastic hose from the water level switch and blow through it to dislodge the blockage.
If it is difficult to blow through,remove the front panel and take the hose off at the air dome on the side of the tub.
Push a small wire into the air dome to clear the clog.
Replace the hose on both ends.
Set the timer for SPIN and run a spin cycle.
Then retry the water level fill.
If it does not fill correctly,replace the water level switch.
Jun 25, 2010 | GE WBSR3140DW Top Load Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
110.20722990 AUTOMATIC WASHER WILL NOT STOP FILLING AND WONT START SPIN CYCLE CAN YOU GIVE ME AN IDEA ON THIS PROBLEM?
There is a clear or white hose that attaches to the drum of the washer on one end, the other attaches to the fill valve, it is common for small unwanted pest ( mice) to chew a small hole in this. Therefor not allowing the pressure switch to recieve the static pressure to actuate it ... or you got a bad pressure switch...
Jul 08, 2009 | Kenmore Washing Machines
Mar 18, 2009 | Honda Garden
G e washer
remove front panel ..with putty knife press clips along edge just beneath top about 2-3 inches from outer edge front will drop off..on left side of tank will be small almost clear hose remove hose by pulling up ckd end of hose for blockage and clean as good as possible if problem still present suspect water level control ..if water continues to run in with power off suspect water inlet valve..remove screws along top edge of console and roll forward to gain acess to control and valve
Jun 18, 2008 | Washing Machines
Honda GCV160 5.5HP 2300PSI GAS-POWERED POWER WASHER Logo
100 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
