Question about Pit SSR 110CC Pro Beginner Bike
Bike shuts off after choke is turned off
When starting the bike,it starts right up with choke on and as soon as I turn the choke off it shuts off, changed plug, cleaned carb stumped????
Cagillari pocket bike starts but won't stay on
usually a carburetor problem, bad gas, fuel filter clogged or CHOKE needs to be turned lower soon after starting - move the choke toward "run" slowly until it is warmed up.
Aug 28, 2014 | Motorcycles
I have a 1985 honda goldwing gl 1200 aspencade i can start the bike it runs fine as soon as it get warm the oil light in dash comes on and motor shuts off i have change oil and filter and the oil pressure...
Hi Most likely your engine shut off first then the light goes on as soon as the engine oil pressure dropped sounds like you have a carb problem and the motorcycle is running on the choke circuit. then it dies after the choke is turned off.
Oct 24, 2012 | Motorcycles
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
Feb 02, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
My 1994 xr6004 has good compression and has had a new top end, it runs awesome and kicks over fairly easy when cold and runs/drives great, but as soon as it warms up and you shut it off or it stalls out,...
The fuel in the carburetor float chambers is boiling while it sits, and flooding the engine. If it has a fuel petcock turn that off, and let the bike stop through fuel starvation. Then there will be no fuel in there to boil.
Jun 15, 2010 | 1994 Honda XR 600 R
Bike starts right up in choke take it off choke shuts off
when you rejetted, did you also change the idle jets or just the main jets? if you didn't change the idle jets, that would probably help. remember you might also want to raise the float level height just a little bit to compensate for the extra fuel going out.
May 14, 2010 | 1993 kawasaki VN 750 Vulcan
When i start the atv with the choke it stays on , but when the atv is started without the choke it shuts off. My atv is a Yamaha grizzly
The choke should only be used when starting cold. After the bike is warmed up you can turn the choke off. If it keeps shutting off after being warmed up for a few minutes, then check your gas/air ratio for the idle air mixture knob. Loosen it up 1/4 turn to allow more gas to flow.
Oct 20, 2009 | 2004 Yamaha YZ 450 F
Bike wont idle or start
try turning the idle up and when you do it give it a little bit of gas
Aug 16, 2009 | 2003 Yamaha YZ 250 F
Choke cable, missing parts?
its common on that bike that when the choke cable breaks the owners are to cheap to replace the cable and operate it right off the carbs
May 13, 2009 | 1998 Suzuki GSF 1200 Bandit S
97 cbr f3 choke and starting out problems
Hi, The mixture is too rich. Was the bike sitting for awhile? The carbs should be cleaned and adjusted. Good Luck!
Feb 19, 2009 | 1998 Honda CBR 600 F(3)W
Pit SSR 110CC Pro Beginner  Bike Logo
56 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Tim Rickards
Tim Rickards
Are you a Pit Cycling Expert? Answer questions, earn points and help others
