Question about RCA HD52W59 HDTV Projection Television
Hd52w68 no power
Power light comes on squeals and does this 3 times
Apc battery backup makes squealing noise, then the power light comes on, why
When there is no power coming into the UPS it will indicate so by 'squealing', during this time - the UPS is on battery. When power returns to it, it turns back to building power and the power light comes back on.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Jul 23, 2013 | Computers & Internet
My D52w23 makes noise and wont turn on keeps trying several times
Does it sound like a sharp short squeal, or a soft wispy whine that coincides with the blinking power light 3 times then stops when the power light each time? If so respond to this same post and I will assist you with the issue.
Oct 25, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD52W59 Power button lights three times when pushed and unit makes squealing noise each of the three times the light comes on then nothing. No power, no light, etc...
replace the flyback which is the 270125 flyback. You can get the 270125 Flyback repair kit at the following link which contains the flyback plus detailed instructions on CD
http://www.tvrepairworld.com/
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
92 saturn sl squeals and loses power
the shift to d2 light comes on when batt. voltage gets low enough that all of the sytems can not function properly. the noise is your bel slipping, your battery looses charge and shift to d2 light comes on to tell you to leave trans in drive 2 so it dose not have to use batt voltage to shift. replace your belt and tensioner if your alternator is ok.
Mar 24, 2009 | 1992 Saturn SL
GE 52" will not power up - green light flashes 3 times
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
http://servicemanuals.vstore.ca/
Feb 07, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Engine squealing
Only two choices a belt pulley bearing or the ps pump.
Sep 22, 2008 | 1999 Mercury Cougar
Samsung TX-P2670WH 26" tv squealing
hi there, you do have a problem at the hozintal section, check the FBT and some parts at the horizontal section and at the power supply section. ty
Jan 01, 2008 | Samsung TX-P2670WH 26" TV
3 blinking lights and no picture
The whine or squealing you hear is either the color wheel or fan. To determine which, when the noise is heard from the set, turn it off and listen carefully. If squealing stops immediately then Tthe fault is the color wheel, not the fan. And sounds like that are generally the color wheel. A new color wheel is Samsung p/n# BP96-00250A for this model. Vance Baldwin carries them for $97.20 plus shipping. https://www.vancebaldwin.com Logon as guest, select parts and copy past the above part number in without any dashes. Good luck... Bill
Jun 08, 2007 | Samsung HLN617W 61" Rear Projection HDTV
RCA HD52W59 HDTV Projection Television Logo
22 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
