Question about Crock Pots & Slow Cookers
Jmb 1522 How do I install it?
How do i find the parts to install my handle back on to my carico rapid cooker
http://shop.carico.ws/Cookware_c5.htm;jsessionid=C3F894518A6256D5CFB6595A14DE512B.m1plqscsfapp02
Dec 22, 2014 | Crock Pots & Slow Cookers
Hasee laptop
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer freezes problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 10, 2013 | Crock Pots & Slow Cookers
When installing steam release valve on 7 qt pressure cooker it is not tight but very loose
Thats the way it is supposed to be. if it was too tight, it would not automatically release when necessary.
Feb 08, 2011 | Wolfgang Puck Electric Pressure Cooker...
Rival crock pot smart pot - low, keep warm & hot lights blink and pot will not heat. is there something i can fix or is the pot destined for the garbage truck?
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
Aug 08, 2010 | Rival 38601 Smart Pot 6-Quart
Need instruction manual for cuisinart csc-650 6.5-quart can you help
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Jul 04, 2010 | Cuisinart CSC-650 6.5-Quart
Need a new rubber seal for the lid of my pressure cooker 6qt
Need to have new rubber installed on my pressure cooker lid, but cannot find anyone to do it. Presto says they do not do the labor but will send me the rubber???? Any suggestions?
Nov 10, 2009 | Wolfgang Puck Electric Pressure Cooker...
Handle to my Rival slow cooker lid model #scve603 broke. not able
If you know a woodworker, get him to turn a knob out of oak, then fasten it with a stainless steel screw and washer. I suggest threading the screw into the knob once before installing it onto the lid so you don't risk overtightening the screw and breaking the lid.
Aug 28, 2009 | Rival 38651-C 6-Quart
Water coming into refrigerator
Evelyn,
More than likely (I can't be sure from here!), your icemaker "motor module" has failed. This module controls the amount of water that goes into the ice tray. If the timer fails, the water valve can stay open. Also, if this is a new unit, or a used refrigerator you just installed, all you may need is to reset the timer on the motor module. The icemaker must be removed to do that. The tray fill time varies with the local water pressure. If your water pressure increases for some reason, the time must be shortened to avoid overfilling the tray.
Jan 17, 2009 | Rival 38651-C 6-Quart
Crock Pots & Slow Cookers Logo
32 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
