Question about Britax Baby Gear
Replacement polystyrene renaissance polystyrene replacement
Need replacement pump for saeco renasissance coffee urn
I need a replacement basket & lid for this model that goes inside the perculater do u guys want to sell the parts?
Question about Saeco Renaissance Coffee Urn - Stainless-Steel
Feb 10, 2014 | Saeco Renaissance Coffee Urn -...
Broken polystyrene in maxi cosi pebble
Broken polystyrene in the Maxi Cosi Pebble doesn't sound very safe. Try reading the user manual for the Pebble:
http://www.maxi-cosi.com/~/media/Products%20Maxi%20Cosi/MCPebble/manuals/MAN_DRU1036_Maxicosi_Pebble_2013_LR_ENFRDENLESITPTJAPLUKHRSKHE.ashx
and definitely contact customer service:
(800) 951-4113
consumer@djgusa.com.
Nov 06, 2012 | Baby Gear
REPLACING FOAM
The polystyrene is what protects your baby from harm in the event of an impact. It is not recommended that the seat is used with damaged polystyrene.
You can obtain a replacement polystyrene via your local retailer or by contacting the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 (Excluding Bank Holidays)
May 29, 2012 | Dorel Maxi-Cosi By Bebe Confort Streety...
I need an inner replacement side protector system, where can i get them from?
Hello Kirsty - The original Maxi Cosi Priori carseat was discontinued in the UK some time ago and replacement polystyrene inserts for this product are no longer available. If it is a Maxi Cosi Priori SPS, XP or Fix model, you can purchase replacement polystyrenes via your local Maxi Cosi retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Aug 10, 2011 | Maxi-Cosi Priori
How do you replace the 'after filter' in the electrolux guardian?
1. Press latch and open the door that covers the tools.
2. Squeeze clips at front of tool tray, lift and remove.
3. Remove filter.
4 Replace filter.
5. Replace tool tray and close door..
Instructions can be found in the Renaissance manual, which you can download from the following site. Go to "older models", find Renaissance and click on it, then click "download". Instructions are on page 9. The Renaissance is basically the same model as the Guardian.
http://www.aerusvacuums.com/support/manuals/
Nov 28, 2010 | Electrolux Guardian Bagged Canister Vacuum
Polystyrene snapped britax first class
If you are a UK resident, then contact 01264 386034 or email service.uk@britax.co.uk who will be able to sell you the required part.
I hope this helps.
Aug 01, 2009 | Britax Eclipse Si - Paris Convertible Car...
Baby Gear Logo
27 people viewed this question
Top Britax Baby Gear Experts
thegtw
Jennifer Rock
Jennifer Rock
Dorel UK
Dorel UK
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
