Question about Exercise & Fitness
I bought a Ross Futura exercise bike/eliptical for $20 at a goodwill store I need to adjust the pedalling tension
It is also an elliptical. as you pedal the bars move too but the tension needs adjusted
thehumble1
  • 137 Answers
SOURCE: healthstream genesis exercise bike
This depends on the model you have. There are lots of genesis bikes have manual resistance knobs on the main post, right in front of the seat. If it doesn't have a knob here, then it might be electronically operated in which case there might be a problem if it isn't adjusting with the program.
Posted on Oct 03, 2008
  • 31 Answers
SOURCE: The tension adjustment does not get difficult enough
If you are refering to a regular bicycle this means the derailer is not making the chain jump from gear to gear. You probably need a new shifter cable or the shifter cable came unhooked from the derailer. I would take your bike to a bike shop to have this reconnected and then they will adjust it for you.
If you are refering to an exercise bike then here may be your solution. From what I have seen on exercise bikes there are three different kind of bikes. I am refering to how there resistance works.
First type has a strap that wraps around the wheel. There is a some kind of a nut and a bolt that holds that strap around the wheel. You simply need to tighten that nut. The strap will stretch over time and that is why you do not have the same resisteace you had when the bike was new. Afer you tighten this you will find that regular tensioner works better.
The Second type of exercise bike has what appears to be brake pads contacting the wheel. Basically your peddaling the bike with the brakes on. Pretty simple concept. Again there should be some sort of adjustment around this pad that is touching the wheel. Probably a screw or a bolt. Some even have adjusters that you can turn with your fingers.
The new and improved exercise bikes have what is called magnetic resistance. This is where your resitance is created by a magnet and some sort of power source such as batteries or your bike being plugged into a wall outlet. If you are using batteries replace them. I found that with my elyptical exerciser new batteries made a world of difference in the resistance settings. If changing the batteries doesn't help then there may be another problem. This could be the computer. Just check your user manual and I am sure you can get it replaced.
Posted on Mar 14, 2009
  • 31 Answers
SOURCE: The tension on the recumbent exercise bike does not get hard
If your bike has magnetic resistance and you changed the batteries this should make your tension work properly. Since it did not I believe that there are magnets somewhere on your bike that are wearing out. Or it could be a computer part. Your manual should tell what part you need to order and replace. I hope this information has been helpful.
Also make sure the batteries that you put in your bike are really new ones. Sometimes you can purchase new batteries at a store and they are actually a little weak. I had this problem with an elyptical trainer and I went and got other batteries and this fixed the problem.
Posted on Mar 16, 2009
OakRun
SOURCE: Wanted:Owners manual for DP Air gometer exercise bike
Scanned image of the 14 page manual that came with a DP AIR GOMETER Model 14-3800B that was purchased in 1991 is available at http://sites.google.com/site/oakrunsite/
Posted on Apr 12, 2009
greenspan
  • 1734 Answers
SOURCE: Exercise bike will not load
Check the manual. If you don´t have it, check here Reebok manual
Posted on Jul 23, 2009
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
Need pedal for Stamina 890 bike
The following link will help you determine the pedal shaft size. If you can identify the correct shaft size, chances are, you can replace the pedals with an aftermarket set. The second link will take you to some aftermarket pedal options.
Identifiying the Proper Size Pedal for Your Bike
Pedals for Exercise Equipment Bikes Ellipticals Steppers SPD 1 2 9 16...
Jan 28, 2014 | Cycling
890 stamina bike need a pedal
Eliptical 9500 HR lifefitness lights then stos
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Start by checking your battery for the proper voltage output. The following are some helpful videos.
Nov 10, 2013 | Life Fitness Remanufactured 95Xi...
Where can I get parts for the ross futura 950 exercise bike?
Where can you get parts for Ross Futura 950 Exerciser
Nov 18, 2012 | Exercise & Fitness
Looking for a manual for Vitamaster 55C exercise bike.
I own one of these babies, I see no need for a manual; does any manual point out the weaknesses of anything ?
Todays, manuals are 50% safety **** agenda and 49% in foreign languages.Tht 1% is common sense..
The welding at the pivot fork was no good...its "fun" when this completely breaks..
However, this bike cost me nada, 0.0, free......
so now its $10 or $20 for welding this piece..
Jan 03, 2012 | Cycling
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
I am looking for pedals to a Vitamaster Air 990 exercise cycle. I was informed Vitamaster is defunct when I called their 800 number. I also called S&R Workout Warehouse and they do not provide parts...
Most of the time you can find an aftermarket pedal that will fit your bike. The important part is the size of the pedal shaft. Most commonly they are either 9/16" or 1/2". I will post a link to a video on how to measure the pedal shaft diameter as well as a link to some possible replacement pedals.
Mar 17, 2010 | Exercise & Fitness
Mar 14, 2009 | Cycling
Exercise & Fitness Logo
57 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
