Question about Dryers
Dryer squeaks while drying sounds like drum rubbing on something
While drying sounds like drum rubbing on something
  • Raymond Ramirez
    Raymond Ramirez May 11, 2010
    have you repaired the drum support roller. this is what normally is the cause of the squeek?
  • 999 Answers
A squeak can also be a slipping belt or something caught between the drum bearings usually the front but could be the back one.
Posted on Jun 14, 2009
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Jan 01, 2013 | Bosch Nexxt WTMC 3300 Electric Dryer
I have a kenmore 400 series and it sound like the drum is rubbing on something and thiere's a gap between the front and back of the drum
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 20, 2011 | Kenmore 400 6942 Dryer
The dryer squeals extremely loud when drying. It sounds like metal scraping against metal.It appears the drum may be rubbing against something. I have lubricated all moving parts.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a high pitch squeaking noise
This could be a dry support bearing, a dried out drum seal or something stuck in the drum seal. If I could hear it I would know better where to start. Listen and try to locate the source from the above list. It could be the belt but that is not as common.
Eric
May 20, 2010 | Dryers
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
The dryer was squeaking when it was on but know it
possible worn bearing.the more wear on the bearing the lower the drum will be.the drum sounds like its rubbing the bottom of the dryer.check for black dust behind the dryer
Feb 20, 2010 | Amana Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
It squeaks as the drum rolls. It still dries the
your drum glides need replacing unless you have had it apart and the drum is not seated properly and its rubbing now
Aug 30, 2009 | GE 7.0 Cu. Ft. 8-Cycle Super Capacity...
Inglis Citation dryer still squeaks
just an idea.....try to match the squeak to the revolutions of the drum or the guide pulley.
if the squeak is fast it is probably a guide pulley or a roller that the drum rides on. if the squeak is farther apart then the drum is wearing in one spot and rubbing on something. check for wear spots around the drum area.
hope this helps.........jay
Mar 21, 2009 | Dryers
My Dryer squeeks while rinning
If it is a constant squeak no ups or downs then its the bearings in the motor that turns the drum. If the sound is not monotone, meaning up and down squeaks, then the drum is rubbing something foreign.
Nov 10, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
327 people viewed this question
Top Dryers Experts
Marvin
Marvin
