Question about Fisher and Paykel Dishwashers
Fisher paykel cross draining
Our DD603 fisher paykel dishwasher's top drawer fills up with water after running the bottom drawer, but the bottom one doesn't fill up with water when the top one is run.
  • Fisher and P... Master
  • 3,247 Answers
As the drawers share a common outlet to the kitchen sink drain, it is the drain water from bottom drawer going to top drawer. Can happen if the drain hoses are not following the correct specifications for installation. An air gap kit is available to solve the problems.
Refer
http://www.genuineapplianceparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/?preadd=action&key=WT50
Posted on Apr 03, 2014
5 Suggested Answers
Master_Tech
  • 770 Answers
SOURCE: fisher paykel
Check your email
Posted on Jul 09, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel DD603 top drawer will not drain
Hi and welcome.
Either your hubby forgot to knock the plug out of the dishwasher connection on the new disposal, or he does not have a dual-air gap installed and the hoses to the dishdrawers do not have a high loop to prevent back-siphoning into the drawer...
Posted on Jan 07, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
ztom2001
  • 9 Answers
SOURCE: my bottom dishwasher drawer won't drain fisher and paykel brand
SOLVED! Remove the white plastic shield under drawer, look for the small green U-board circuit board near the center. If it's loose, that's the problem because the board has a sensor that detects the rotor spinning and if loose the computer gets confused. Slide the board into place, so one end of U-board is close to center, you can see where it slides in. I took a 1/4" diameter wad of 15min epoxy putty an secured the bottom corner of the board.
Posted on Jan 25, 2013
Fisher & Paykel dishwasher top drawer is filling up with water when bottom drawer is ran.
It is the drain water from bottom drawer that is finding its way to the top drawer. This could be due to incorrect drain hose height. Check in installation manual. Alternatively you will have to buy an air gap kit and connect the two drain hoses separately to the kitchen sink.
http://www.genuineapplianceparts.net/ecart/item.php?item_id=250&category_id=58
Mar 22, 2014 | Fisher and Paykel Dishwashers
Fisher and paykel dishdraw model DD603
P2 is for drain. Make sure there is a bit of water in the base of drawer before you start P2 otherwise the rotor may rub and burn. You can run the diagnostic with drawer open. Be careful not to start P1 as the wash water will splash and flood the dishwashwer.
Jan 28, 2013 | Fisher and Paykel Dishwashers
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Appliance: Fisher&Paykel DD603 Draining
You may want to check up if the water collects in the bottom drawer when the top drawer is in wash cycle (ie, taking water from the inlet) or during the drain cycle when it is draining water out. Leave the bottom drawer open and check while the top drawer is running.
Jul 27, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Hi and welcome.
Jan 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
FP DD603 draining problem
This device will solve the issue of cross-draining between drawers on Fisher paykel double dish drawers.
http://fisherpaykelparts.net/index.php?categoryid=1&productid=7
Aug 10, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishwashers Logo
427 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
