Question about Dell XPS 200 PC Desktop
Is there a mic
Do I have a microphone in the xps 200? If so, where is it?
What is the difference between DM-H100 & 200?
One is a $20 mic and the other is a $30 mic. Both are "karaoke" mics. I can buy an AIWA DM-H100 Cardioid Microphone for $5 on eay and an Aiwa DM-H15 Cardioid Dynamic Microphone for $6.
Aug 31, 2014 | Aiwa DM-H200 Microphone
Disable mic on xps m1730
Right click on the speaker icon in the system tray (bottom right, next to the date/time) and select recording devices. It will give you a list of whatever devices you have on your computer that are designated to record sounds. Choose the on board microphone, right click, and select disable device.
Feb 16, 2014 | Dell XPS Computers & Internet
Xps 8500 mic
Update the drivers for the mic
Go to Start
Click in box and type Device Manager
Click on Device Manager in the list
Click on Sound,video and game controllers
RIGHT click on the microphone
Click on update drivers
Click on Search automatically for updated driver software
Apr 02, 2013 | Computers & Internet
Telex ht200 is fatter microphone and I am looking for a microphone clip to mount it on a microphone stand. Universal clips are too skinny - they will not fit around the mic. Does anyone know where I cn get...
Here you go. I would use something like this. This has a 1.75" (44mm) diameter. http://www.bhphotovideo.com/c/product/298898-REG/WindTech_MC_4_MC4_Extra_Large_Heavy_Duty_Microphone.html
You can also go here http://www.crossroadsaudio.com/Rentals%20Catalog.pdf scroll down to page 5 and you can use this - $15.00 Telex ELM-22S Black Lapel Mic, Shure TA4F w/ Mic Clip -- That clip is the same diameter as your mic and is made by Telex.
Mar 22, 2011 | Telex HT-200 Handheld Microphone...
How to check if I have an internal microphone on my dell Studio XPS 435 with windows 7?
Find the speaker icon in the task bar. Usually lower right hand side near the time and date location. Right click on it and select recording device. In the window that opens you should see a microphone icon and be able to talk and see the level change on the bar graph. If the mic is there but no audio moves I'd go ahead and double click the microphone icon and another window tab will open up. Look at all the sitting in those tabs for anything that maybe muting the mic.
Jan 21, 2011 | Dell Studio XPS 435 PC Desktop
My dell xps mic volume only records a faint sound
well thats same with my dell laptop, i did a lot of things but i came up with 1 solution
if you can buy an external microphone
Apr 14, 2010 | HP Compaq 6720s Notebook
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Oct 06, 2009 | AKG Perception 200 Microphone
My microphone not working on my dell xps 420 vista system
double click on the speaker and make sure that the mic does not have the mute box with an x in it.
I am pretty certain you have a card in your computer for it mentions a 7.1 speaker system.
If you put your service code in to do a search for drivers you will get the correct ones for your particular machine. Download install and reboot.
If you are not using six speakers and one sub woofer then the pink one in the back is the mic
May 14, 2009 | Dell XPS 420 PC Desktop
Microphone
plz check you have inserted the jack in correct port, if it is correct then check you have install the correct driver.if every thing is ok then your microphone may be kaput.
Jun 30, 2008 | Dell XPS M1530 Laptop
Dell XPS 200 PC Desktop Logo
21 people viewed this question
Alun Cox
