Question about Maytag EPICz Electric Dryer
Clean lent filter
Light is flashing clean lent filter every time you start dryer
    Scholar:
  • 111 Answers
The unit is seeing a restriction in air flow disconnect the exhaust at base of machine turn to air dry or fluff you should get good air movement coming out of the exhaust I will assume the machine worked when new if flow is weak then there is lint in the blower air passage from the machine if good you will know the difference the the restriction is in the exhaust exiting the house on one occasion i did encounter a bad control if everything passes the test an dryer is operating correctly and you still have a light leave it control is not cheap for an annoying light
Posted on Mar 23, 2014
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
My kenmore dryer wont click on, it will light up and click but nothing happen's I cleaned out the lent trap and the lent funnel and it still wont click on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 19, 2011 | Dryers
My Bosch wtl6304 condenser tumble dryer keeps indicating empty filter light and bleeps rapid. It warns me twice like this then trips the thermostat out. I have cleaned filter, washed the condenser out and...
never really heard of a condenser model dryer before however it does seem like internally its full of lent inside of the dryer housing itself around the heating elements if you have a large air compressor open it all up and spray air into everything in the dryer where you see lent build up this will force any lent out of the dryer and it should hopefully run as the day you first got it ;P found this to be an issue even with an LG TROMM dryer i opened up and wasnt drying very well
May 06, 2017 | Bosch Axxis WTL 6307 Electric Dryer
I have a lg tromm dryer model #dleo442w. my check filter light blinks before i start it. how do i check filter? I always clean the lent trap so i know thats not it. thanks
Ours does the same thing. We bought it used so did not get a manuel with it, but I think it's the same thing. I think it flashes to get peoples attention. Maybe it's a safety feature to help prevent fires.
Nov 12, 2010 | LG Dryers
I HAVE A KENMORE 400 SERIES DRYER. THE LENT NO LONGER STICKS TO THE FILTER. WHEN I PULL THE FILTER OUT TO CLEAN IT, THE LENT SLIDES OFF THE FILTER CONTINUALLY CLOGGING THE VENT IN THE BACK OF THE DRYER....
Try cleaning the filter to remove any residue from dryer sheets (a dish detergent solution should cut the softener build-up). Be as gentle as possible. An old toothbrush is useful for this.
Also, a weak exhaust flow may be the culprit. Check the dryer vent line all the way outside for excess lint.
Your fan impeller (inside the dryer) may be loaded with lint, too.
Apr 29, 2010 | Kenmore 400 6943 Dryer
Lent seems to be going all over the house. The lent is very fine almost like dust. The discharge vent pipe is not leaking.
when was the last time you cleaned out the dryer?you need to clean out the duct that the lint filter slides into,remove the vent line from the back,if it's a long run blow it out with a leaf blower to clean it out,before you blow it go outside and make sure the duct where the flapper is isn't blocked with anything,and then vac out the inside of dryer where the motor is,you should do this once a year so the dryer works properly and your clothes will dry on time
Mar 19, 2010 | Whirlpool LER4634J Electric Dryer
Not drying completly seems not alot of lent on lent filter
Your rear connecting exhaust vent must be removed and cleaned out.
If it is the flexible vent material it must be un-kinked or mashed when reattached.
Run a 50 minute timed dry cycle with the vent completely off.
If the load dries OK,the connecting vent is the problem.
Jan 17, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Clean filter light flashing and making more noise than normal
There is an element where the lent screen is. It is the dry sensor. Check to see if it has lent on it.
Jun 27, 2009 | LG DLE5932W Electric Dryer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
Maytag EPICz Electric Dryer Logo
80 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
