Question about Promethean Board Promethean - 6103408569-ny - Prm-10 Projector Lamp
Where is the PRM-10 Thermal Switch located?
How do I reset the thermal switch in a PRM-10 projector?
Can you tell me where I would find the thermal reset button ?
Hi!You need to check the back side of the lamp housing on the inner side of the projector. you will find it sitting on the top.
press the small button over the thermistor which is a round unit with a red or a black reset switch over it!
Jun 03, 2015 | Sanyo PLC-XW200LMP XGA Projector Projector...
Replace color wheel
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | Promethean Board Promethean Prm-25 Super...
Green light on prjector PRM 35 will not stop blinking and the projector will not come on
open the case, and reseat the ribbon cable at both ends.
5 screws on the bottom and 3 screws inside the lamp housing to open the case. Be careful not to break the 2 plastic clips in the back.
Also check the micro switch on the lamp door is working correctly.
Mar 10, 2014 | Promethean Board Promethean PRM-35 DLP...
Prm35 white dots
The white dots mean that the DLP chip has dead pixels. This can't be repaired by your average Joe or Josephine. The only time I ever "fixed" this problem (I fix these professionally), was when I happened to have another PRM-35 that had a bad power supply board. I was able to take the whole lens assembly (which includes the DLP chip) out of that machine and put it into the one with the little white dots. Check and see if it is still under warranty. If you have some extended plan, maybe you can get it replaced.
Feb 24, 2014 | Promethean Board Promethean PRM-35 DLP...
No power from my Sanyo PRM 30 projector
Hi Tim,
It sounds like you might be having an issue with the power supply in which case the power supply would require replacement. Feel free to message me at david@digitronelectronics.com and I will send you some details. Home
Jan 23, 2014 | Office Equipment & Supplies
I need instructions on how to replace the lamp in the promethean prm-25 projector
Make sure projector is unplugged and cooled down, lamp can be very hot
Remove the cover over lamp area
There are 3 screws in lamp unit (they have little arrows that point to them even) or check against new lamp to make sure you take out the correct ones
Pull straight up, place new lamp in securely and screw back down (screws are attached to each lamp set)
Place cover back over lamp area and screw closed
Reset lamp hours by hooking up your computer to board
Get to lamp reset screen
Press down up left right arrows in sequence then press return button in middle
Jan 26, 2013 | Promethean Board Lamp for PROMETHEAN PRM25...
Where can I find thermal reset switch on my sanyo plc xu115? thanks
the switch should reset itself after it has cooled off, but it is typically near the housing of the bulb to read the temperature accurately.
Looks like this:
Feb 10, 2011 | Sanyo PLC-XU115 Projector
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
No power
No Power "Whatsoever"
I Followed all the instructions in aarrowgant post
when I got to the fuse I removed it and checked it with
my ohm meter, and guess what it was not blown!!!
I used a can of gas duster to blow out unit.
I reassembled the projector except for the top of case and
plunged it in "No Power" I disconnected The power
There is however a small thermal switch I Noticed mounted
on the front of the lamp housing only accessible with the case
top off, It has a small red plastic reset button on it. I dusted
this off and pushed it. pluged it back in and the power light came on followed by the projector powering up. I reinstalled the top and mounted projector back on ceiling. Working fine now 48 hrs.
This entire proceeure took me 2 1/2 hours and cost me nothing.
Good Luck,
cyberphx
Nov 05, 2007 | Sharp XR-10X Multimedia Projector
Promethean Board Promethean - 6103408569-ny - Prm-10 Projector Lamp Logo
65 people viewed this question
Top Promethean Board Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Promethean Board Office Equipment and Supply Expert? Answer questions, earn points and help others
