Question about Konica Minolta Office Equipment & Supplies
3b04 error 3b04
  • Konica Minolta Master
  • 6,161 Answers
Model number would help
Posted on Jan 14, 2016
How can i remove a trouble code '3b04' that appear at my printer konica minolta bizhub c-451
" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Sep 29, 2015 | Konica Minolta Bizhub C451...
C-3b04 err
Turn off the main power sw inside machine not the one on side of control panel. Hold down utility/counter and turn on main power close front door wait for trouble reset. touch trouble reset. wait for OK then power machine off wait ten seconds power machine on again should come up to ready to copy. IF code comes back do not reset again machine is telling you it need help have it looked at by a technician.
Jul 12, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Code d'erreure c-3b04 at conika bizhub 451
The unit that provides high current to the magnetic field of the fuser is bad, located below the control panel and behind a cover, recommend tech look at it can be very expensive.
Apr 28, 2014 | Konica Minolta Bizhub c203 Copier
As before, The unit that provides high current to the magnetic field of the fuser is bad, located below the control panel and behind a cover, recommend tech look at it can be very expensive.
Code c-3B04
Fusing unit issue! Have to reset with PWR off the machine using both the main pwr inside front cover and sub pwr on the side of the op panel then turn on the machine holding down the Utiliy/counter button. unit the Trouble reset show on the screen then press trouble reset until says OK the Power off the machine with Main power switch inside the front cover, Wait ten seconds before doing that. If it comes back do not re do its broke and telling you so get a certified tech to look at it.
Oct 03, 2013 | Konica Minolta KONICA BR BIZHUB C451...
Need a error list for a Canon IR 600 imagerunner
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
E490 wrong DF type
E500 finisher communication error
E503 finisher internal communication error
E505 finisher backup memory error
E514 stack delivery/trailing edge assist motor error
E519 gear change motor error
E520 off-set motor error
E530 rear alignment error
E531 stapling error
E532 stapler shift error
E535 swing error
E537 front alignment error
E540 stack tray ascent error/upper tray ascent error
E542 lower tray ascent error
E577 paddle error
E584 shutter error
E590 punching error
E591 puncher dust sensor error
E592 punch horizontal registration sensor error
E593 punch shift error
E5F0 saddle paper positioning error
E5F1 saddle paper folding error
E5F2 saddle guide error
E5F3 saddle alignment error
E5F4 saddle rear stapling error
E5F5 saddle front stapling error
E5F6 saddle butting error
E5F8 saddle connector error
E5F9 saddle switch error
E602 hard disk error
E604 image memory error/shortage
E609 hard disk error
E610 herd disk coding key fault
E674 fax board communication error
E710 IPC initialization error
E711 IPC communication error
E716 communication error for pedestal/ communication error for 3-way unitA1
E717 communication error for NE controller
E719 coin vendor error
E730 PDL software error
E732 scanner communication error
E733 printer communication error
E740 Ether board error
E743 DDI communication error
E744 language file/boot ROM error
E745 TokenRing board error
E746 accessories board wrong model error
E748 controller board and SDRAM size mismatch
E805 fan error
Aug 07, 2013 | Canon imageRUNNER 600 Printer
Code erreur c3b04
what solution for the trouble code c-3B04 for c650
Apr 01, 2013 | Konica Minolta BizHub C650 Copier
Trouble code C-3B04
[1] Turn off the powerswitch behind the little white cover
[2] Hold down the utility /counter buttom while power on and hold it until the hourglass shows.
[3] After a while the displays shows a trouble reset, press it and you will get ok i result.
[4] Power off/on again.
Oct 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Canon ir 3530
E490 wrong DF type
E531 stapling error
E535 swing error
E577 paddle error
E584 shutter error
E590 punching error
E805 fan error
Feb 21, 2010 | Canon ImageRUNNER 3570 Copier/Printer
19 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
