Question about Fisher and Paykel GC36 Gas Cooktop
Countertop keeps on clicking until gas is turned on fisher pakal
Keeps on clicking
Back right burnor ignitor will not turn off, even when knob it turned to off of GC36 gas cooktop
Hi staneand,
I believe your ignition switch has come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 27, 2011 | Fisher and Paykel GC36 Gas Cooktop
Im trying to install this cooktop maytag mgc7430ws, there are two brackets in it and there is absolutely nothing in the instructions about how to attach it to the cabinet
I just put one of these in. You're right, there is nothing in the instructions about this, I had to figure it out for myself.
Your kit includes two brackety-shaped steel brackets and two long screws. Look on the bottom of your cooktop, halfway between the front and back on the left and right edges and you'll see a hole on each side. They are the only holes on the bottom.
Manipulate the brackets until you see that the hole in the bracket matches the hole in the bottom AND the bracket fits upward along the side of the cooktop. The flange on the top end of the bracket goes against the bottom of the countertop.
It's useful to have another person lift each end of the cooktop while you insert the bracket from below.
Once the brackets are in lace, center the cooktop so it's straight on the countertop, then screw the brackets to the bottom of the cooktop. They will tighten against the countertop and make the cooktop stop wiggling.
May 31, 2011 | Maytag MGC7430WS Stainless Steel Gas...
Electrode sparking
Here is a tip that I wrote that will help you to find out why the sparker keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 29, 2010 | Fisher and Paykel GC36 Gas Cooktop
Piezo goes off every 10 seconds.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
heatman101
Apr 10, 2010 | Whirlpool SC3017RQ 30 in. Gas Cooktop
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
Fisher and Paykel GC36 Gas Cooktop Logo
93 people viewed this question
Top Fisher and Paykel Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Fisher and Paykel Cooktop Expert? Answer questions, earn points and help others
