Question about Radio Shack Pro-97 Handheld Scanner
All channels locked out - Radio Shack Pro-97 Handheld Scanner
  • Radio Shack Expert
  • 509 Answers
Press scan, then press a number button and it will scan that bank -pick a number from 0-9 and it should scan that. If you did truly lockout everything hit 'manual' then hold down the L/O Lockout button for 3 seconds and you'll hear a beep- that should unlock everything.
Posted on May 01, 2017
My 42 FD 9954 Philips flat TV monitor has a channel lock I can't get it unlocked what do I do
How to lock or unlock channelsTo lock or unlock channels:
  1. Press the Menu button on your remote control.
  2. Select Settings.
  3. Highlight System and press OK/Select.
  4. Select Parental/Purchase.
  5. Enter your Parental Controls PIN.
  6. Select Parental Preferences.
To lock or unlock all channels:
Select Lock All or Unlock All and press OK.
To lock or unlock specific channels:
Select Block by Channel > Add or Remove Channels.
From there you can select to Lock All, Unlock All, or
select specific channel(s) that you'd like to lock or unlock.
Jul 21, 2015 | Philips Televison & Video
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
All channels are locked out how do i un lock them
To remove the lockout from a channel, manually select the
channel and press L/OUT so LO changes to lo.
reviewing locked-out channels
To review all locked out channels, press MAN. Then repeatedly
alternate between pressing FUNC and then L/OUT to view each
locked-out channel. When you fi nish reviewing locked-out
locking out frequencies
To lock out a frequency during a search, press L/OUT when the
scanner stops on that frequency. The scanner locks out the
frequency, then continues searching.
From the manual:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-97_OwnersManual_ome20-527.pdf
Please remember to rate my solution.
Jul 03, 2011 | Radio Shack Pro-97 Handheld Scanner
Pro-96 ,channels 1 thru 9 are locked out ,only 0 is
You are referring to banks, not channels. When bank 0 is active, then you push 0 to de-activate it, you have now removed all your banks from the scan list. To re-activate any bank, just press any number. This is confusing because locking out a channel and removing a bank from the scan list are two very different operations but use the same terminology.
For more information and some tutorials to help with various functions, visit this site: http://support.radioshack.com/support_tutorials/communications/20-526.htm
Feb 11, 2010 | Radio Shack Pro-96 Scanner
I was given a mitsubishi tv but the previous owner had a password lock on it. Is there any way to access the tv by rebooting or something in order to use the tv?
1. Press the Mode button until the LOCK CODE display appears.
2. Enter the 4-digit code using the CHANNEL SELECTOR buttons.
3. Press the CANCEL button to cancel the previously locked channel. The LOCK CODE number display flashes.
4. To exit the CHANNEL LOCK mode, press the MODE button until only the Time and Channel display appear.
Secret text if the code is forgotten!
2. Press Channel Number "9" and "QV" simultaneously. Knowledge of this procedure defeats the channel lock system.
Nov 12, 2009 | Televison & Video
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
Uniden BC72XLT compact scanner
Hi, this is from the manual,
Locking Out Channels
You can increase the scanning speed by locking out channels that have a continuous transmission, such as a weather channel. To lock out a channel,
manually select the channel, then press Func +L/O.
L/O appears.
Note: You can still manually select locked-out channels.
select the channel, then press Func + L/O.
L/O disappears.
I hope this helps you out,,, Mechanic
If you need a manual, go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
Jan 22, 2008 | Uniden BC72XLT Handheld Scanner
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi tv
Without the code, you must get an original remote and press the "QV" and the "9" buttons together to unlock the TV.
Oct 16, 2007 | Televison & Video
Radio Shack Pro-97 Handheld Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
