Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
On/off switch not working
The on/off switch isn't working
  • 4 Answers
This machine model is a real bear to work on. It's a relative to what used to be called the "special model". I'm not sure if they purposely engineered it so that it was extremely difficult to repair or if that just came as a by product. If the switch is the problem you have to take the housing apart with the unit laying upside down, and this is accomplished by removing the rubber side bumpers by grabbing them at the rear of the machine with a pair of long nosed pliers and pulling. Sometimes they come off fairly easily, most times not. Once the bumpers are off, the unit becomes two halves. Lift the bottom section off and lay it aside while you take the vac bag chamber out of the top section and lay it aside. You should be able to see the switch at this point so that you can remove it and check it for continuity on and off. If it's faulty then you need to order a new part, if not then you need to check the cord assembly to make sure that's good. Whatever you find that's bad will need to be replaced, then re-assemble the unit and it should work fine.
Posted on Mar 22, 2014
My hoover savy U1825 isn't sucking in carpet mode
take the brushbar off and unblock the pipes they will be blocked with dirt and fluff
Nov 12, 2012 | Hoover Vacuums
Where do you put the prefilter on a miele canaster vaccuum
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Sep 11, 2012 | Miele S514 Solaris Electro Plus Vacuum
My coffee maker isn't working! the water isn't filling into the maker to make the coffee. if begins to fill but then stops abrubtly. please help
You could try to clean it out with white vinegar, it might take several times before it works but it will usually get the lime deposits. Just run it through like it was water, but make sure that you have a filter in so that you can tell when the chunks start passing through.
Aug 07, 2011 | Vacuums
I have a Bissell ProHeat Turbo 2x, it isn't mixing the water & cleaning solution and isn't spraying. What do I do?
Isn't Spraying:
Possible Problems->Solutions
-Water Tank may be empty-> Fill Heavy duty bladder with hot tap water.
-Formula Tank might be empty-> Fill with Bissell fiber cleansing formula for cleaning.
-Tanks may not be seated completely-> Turn power off and reset the tanks.
-Pump may have lost prime-> Turn power off, then on again, wait one minute then depress the trigger
You can also contact Bissell at: 1-800-237-7691 begin_of_the_skype_highlighting 1-800-237-7691 end_of_the_skype_highlightingto help you out on why the cleaning solution and water aren't mixing, but first try fixing the first problem, you never know, it might cure the first one. :)
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Bissell Vacuums
My apple ipod touch wont turn on
I've seen this before. You need to reset it.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
I hope this works!
May 10, 2011 | Vacuums
The motor on my Epic 6500 works, the hose is sucking, but the power head isn;t working... I tried the sidestep power head and that one works. Ive opened and replaced the belt and that is fine. The bulb...
Connect the power nozzle directly to the hose and try.
Check the terminals where the wand connects to the PN. If any are discolored or cracked, that may be the problem.
Open the PN and check for loose or broken wires and connections. Repair or replace as necessary.
The reset switch could be broken or worn out. You can check this with a continuity tester or multimeter.
If none of these solve the problem the vacuum needs to be taken to your local Aerus Electrolux store for diagnosis and repair.
http://www.aerushome.com/storelocator/
Feb 14, 2011 | Electrolux Epic 6500 Vacuum
Motor wont turn on.I checked the switch and I think it is working.motor turns on if a put direct power to it.`but it smokes at the brushes. can you help?
This sounds like either the belt isn`t on right or the brush is not slotted in the vacuum right remove the plastic or metal cover from the bottom and check by inspecting the belts ability to easly turn the brush rod check with your hands DO NOT turn vacuum on while plate cover is off it could fly off and cause injury.
Sep 05, 2009 | Kirby G4 Bagged Upright Vacuum
I cant find fuse on my kirby sentria. Any suggestions?
there isn/t a fuse if not turning on probably a bad switch or power cord
Jul 18, 2009 | Kirby G6 Bagged Upright Vacuum
Vaporetta polti VTT2085 1998
The solenoid isn,t operating. Either the valve is stuck or the coil is burnt out
Dec 26, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
21 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
