Question about Panasonic KV-S3065CL Path-Through Scanner
Code: 00000004 failed to find the current scanner
How do I check airbag connector under seat the airbag light is on and it failed mot because of it ?
Airbag system failures are difficult to identify and correct unless you have a scanner that can read the codes from both the primary airbag system and the Passenger Presence Module. Since the voltages and currents are low, it is common for corrosion in connectors to cause the system to fail. So get or borrow a scanner which will tell you exactly what is wrong and if it is an open circuit, remove the seat from the floorboard and tilt it back a bit to better access the connectors and clean the pins and sockets with alcohol and a swab. Test the source connections for the proper resistance to ground and voltages using the service manual as a reference. Continue to use the scanner to see if the problem clears up by clearing the code and checking to see if it returns. If the source connector pins are good and cleaning didn't solve the problem, grease them with a conductive grease.
Feb 28, 2015 | 2005 Chrysler PT Cruiser
Tip
Handheld Barcode Scanner service
Do you currently have hand-held inventory scanners?
Although you may not be familiar with Legacy's Technology Services, we may already be servicing your barcode scanners, barcode printers and even POS hardware. Many sellers of extended maintenance contracts have used Legacy for years to perform service on devices covered by their contracts.
Maybe you're looking for a specific hard to find part. Chances are I've got it!
We also carry refurbished equipment if you are in the market.
Give me a call for a quote and to discuss your current needs.
Joe Anselmo
Legacy Technology Services Inc
(630) 622-2018 ext. 418
Email: janselmo@legacyglobal.com
on Apr 13, 2009 | Zebra LS1203 Bar Code Reader - Handheld...
Whats the difference between a current code and a pending code?
Pending codes and current codes are basically the same. Pending codes are for a problem that is still indicated to be a problem,but hasn't been cleared. Current codes are codes that are indicated for the current drive cycle. Usually will both be the same code if problem still exists and hasn't been cleared without repair.
May 12, 2014 | Cars & Trucks
Action replay codes for pokemon white desmume???
1,024x Experience [North America] 521CB54C 59A8437E
023AE840 59A8437E
023AE844 51A80280
123AE848 00004770
021CB54C F978F1E3
D2000000 00000000
100% Catch Rate [North America] 521CBCF4 7820D203
121CBCF4 000046C0
D2000000 00000000
2x Walking Speed [North America] 52197FE4 1C05210C
02197FE8 085F0056
D0000000 00000000
Arceus Encounter Code(Press Select) [North America] 94000130 fffb0000
c0000000 0000002f
12250030 000001ed
dc000000 00000004
d2000000 00000000
Catch Trainers' Pokemon [North America] 02002300 68006868
02002304 60012100
02002308 00004770
521CBAC4 F7EC6868
121CBACA 0000F636
121CBACC 0000FC19
D2000000 00000000
Have Completed Pokedex [North America] Press Select to activate.
94000130 FFFB0000
0223D1D0 00001803
D5000000 FFFFFFFF
C0000000 00000131
D6000000 0223D1D4
D2000000 00000000
Oct 23, 2013 | Pokemon Video Game Consoles & Games
C-3c50
C3C50 at power up.
PROBABLE CAUSES:
1. Loose connectors or failed PWB-C board.
Reseat all connectors and then replace PWB-C board (p\n 65FA-9360) if necessary.
2. Poor connection for the interface cable between the MFP and scanner.
Reseat the MFP-to-scanner interface cable its a large molex cable with thumb screws to remove on the outside of case.(p/n 4581-6876-01).
3. Failed PWB-F board.
Replace PWB-F board (p/n 4025-0103-27). Flash MFP with most current firmware. The latest version firmware or system software is available via the Konica Minolta Download if you need help with this write me back.
4. Incorrect scanner serial number.
Access service mode and select System Input. Verify the correct scanner serial number has been input under Serial # Input.this is in Service mode. if you need help with this write me back
Nov 29, 2011 | Konica Minolta Minolta CF 2002 3102...
HP Precicionscan Pro 3.1 now starts with this error message: \r\n "One or more ActiveX controls could not be displayed because either: 1) Your current security settings prohibit running ActiveX...
http://support.microsoft.com/kb/907343
You receive a "Your current security settings prohibit running ActiveX controls on this page" error message when you start Project or Project Web Access
Mar 05, 2011 | HP Scanjet 5400c Flatbed Scanner
THE UPPER UNIT FLASHES ON THE SCREEN WITH ERROR CODE 39,003,40;75554
On the Xerox 8560MFP multifunction, this error code 39,003 signifies a Scanner problem, specifically that the Optical Test has failed. the 75554 is your current page count on the printer.
The Scanner Assembly 062K22590 must be replaced. It is fairly expensive, but moderately easy to replace.
You should also order the Scanner Calibration Sheet 109K01910 to make sure that margins and contrast are correct.
The scan/ document section is broken into 2 main parts, the Scanner, and the Automatic Document feeder. The feeder section is probably working fine.
Good luck with that.
Dec 27, 2010 | Xerox Phaser 8560MFP Printer
My scanner has stopped working - my mac cannot find it anymore and when I press the buttons on the scanner it does not light up or react HELP Lesley
From what you're saying, it sounds like the scanner isn't getting power. There's a plug-in AC adapter that provides the power, and it may just be that the plug is loose in the scanner. If you've moved the scanner or stuff on the desk it may have dislodged the plug. Also, check that the adapter is getting power. Is the outlet where you have it plugged working? Or the adapter may have died, which is common. You can probably find a suitable replacement locally at Radio Shack or online. Just be sure to match the voltage and current rating of the original (you can go higher on current but not lower) and polarity of the plug. Or something in the scanner itself has failed, in which case you're best off replacing it. Because the replacement cost is low, you will be hard-pressed to find any professional service shop willing to take this in for repair. If you have an electronic tinkerer friend, maybe he or she can check it out. It might turn out to be a simple fix.
Dec 17, 2010 | Epson Perfection 1670 Flatbed Scanner
Does the Uniden BC 148XLT have a memory battery in it? When I unplug the scanner from the wall outlet , it looses all the frequencies. Also if you know what size it takes, would be...
Sorry, but maintaining memory in your BC248CLT is not as simple as replacing a battery. Your scanner has a capacitor-based backup system, and the capacitor has apparently failed with age. Unless you're skilled at electronics repair, or you have a buddy who is, repair of this classic (circa 1999) scanner will set you back about $100. That makes repair impractical, so you might want to keep your current scanner powered up, and start looking for a replacement. Good deals on used scanners can always be found on eBay, but be certain that you know what you're buying, what condition it's in, and what it's worth.
Bill B.
Listening in since the 60's
Dec 11, 2010 | Uniden BC248CLT Base Scanner
Panasonic KV-S3065CL Path-Through Scanner Logo
1,204 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
